Question about Intuit QuickBooks Premier: Accountant Edition 2003 (275957) for PC
I am locked out of my work because it will not let me get into the system. My quick books is a 3.0 and was registered when I bought it about 4 years ago. I have since installed a new computer. I do not need a bigger or better quick books because I am a small company - self employed and had all of my tax data on the quick books program as is and cannot retreive it.
  • Anonymous Mar 13, 2014
    Quick Books Point of Sale does not recognize company name
    Novelist:
  • 167 Answers
You are locked out of quickbooks on the old computer or new computer?
Posted on Jul 20, 2008
What is p16ff code for nissan
all of my research keeps coming back to p1610 for the P16ff Code but I am not sure.
The code P1610 is a problem with the NATS, or better known as system of vehicle immobilizer. And this arose out of the following:
-are using a q-key is not registered or not transmitting the code
- BCM or ECM are evil, and
now is in "locked mode"
you can do something quick:
1. Confirms the code q yields
2. EXIT THE LOCKED MODE. If the code is p1610 continues with the following with a copy of the vehicle key:
(1) -Place the switch to OFF
(2) -Place the switch in ON with the key registered(do not start the engine). Wait 5 seconds
(3) -Returns the switch to the off position. Wait 5 seconds
(4) -Repeat step 2 and 3 two more times (being a total of 3 times) (
5) -Starts the engine
with this test and write us if t worked. If this is not the case there will be q enter to detail by checking with the diagnostic charts and other things.
The other code does not exist or does not comply with the structure of a code
Aug 03, 2014 | 2007 Nissan Tiida 1.6
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
I have a windows xp home cd that i bought 4 years ago i have had about 4 different computers i used it on but they all went bad so i got another computer and trying to register they wont let me with my...
Yes in order to use you need to call microsoft and tell them that you had bought XP HOME with that product key and have had on the 4 other ones that have died, they will further fix problem for you, call in to register on phone with microsoft
Feb 06, 2010 | Microsoft Windows XP Home Edition
My lg lh-t760sb does not read all types of dvix video files
Why is my home theater system quickly began to see the screen flashing and striped. The sound is good. SCART connector is OK, I checked other devices. My TV has no HDMI but it is LCD. I bought it 3-4 years ago.( ONN ) If you know. So where can be a problem? Thank you.
Jan 16, 2010 | LG LH-T760IB Theater System
Recode a key 4 bmw 318i cenral locking
To carry out this procedure you need to have one working key and one key which requires programming. It may help sometimes to hold the key close to the rear view mirror as this is where the sensor is located in most models. 1. With both keys, get in the car and close all windows and doors. 2. Put working key into the ignition and turn to position 1 (the accessories should turn on) (try also position 2) 3. Turn the key back to position 0 and take the key out of the ignition. 4. Using the working key, hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button. Doors should lock and unlock. 5. With the new key, hold down the unlock button and press the BMW logo (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!! If not working try the following PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation. If this doent work your alarm/central lock needs to be reset
Mar 28, 2009 | 1996 BMW 318
C 400 Latitude display problem
That LOCK A sysmbol is the caps lock.
Most likely its due to hardware failure. Be sure the battery is holding a charge and the power adapter is working.
It could be bad Ram. Usually when there is nothing at all but a quick light on and off and nothing, its due to motherboard issues or hardware plugged into it. Try removing any CD drives or add in devices.
Good luck
Dec 01, 2008 | Dell Latitude C400 Notebook
MY NOTEBOOK IS LOCKED
you probably have to get a code to register widows. I had this same problem it will only give you a few functions because it will say that the windows code is not registered and that it is fake. It could be depending on where you bought the computer or operating system from but if you call Microsoft they could easily fix your problem or give you a new code. Please rate thanks!
Oct 25, 2008 | Gateway 200 ARC Notebook
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
Intuit QuickBooks Premier: Accountant Edition 2003 (275957) for PC Logo
254 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
