Question about Pioneer AVIC-D3 Car DVD Player
Road noise im geting some road noise form my door speakers. how do i eliminate that?
  • patrick12345 May 11, 2010
    WOW. What kind of car. year make model.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Is it a whining noise that changes with the accelerator pedal? Do you have aftermarket amplifiers in the car? There are a number of different noises you could be hearing and a number of solutions for each. Also, if aftermarket amplifiers are connected to the front speakers and the Pioneer radio was powered up and RCA's connected to the back, you may have burned out a diode inside the radio and you'll get "engine noise"
Posted on Aug 11, 2008
Reduce road noise
most of the scions, have very or little noise deffing materials in them, my 07 make lots of road noise when i drive it, most comes from the rear hatch back, im sure that there is some kind of noise reduction materials that you might add on, just need to look on line for it
Oct 24, 2013 | Scion Cars & Trucks
My 2005 dodge caravan sliding doors are very noisy. Too much air and road noise. How can I tighten doors to eliminate noise?
I would check the weather striping first to see if they are worn down. If that doesnt work ur dooors might be tweaked to where they arent sealing off very well. U can try to tighten at hinges but if its not possible the alternative is go to junkyard to get another door!
Oct 30, 2012 | Cars & Trucks
The noise that the car makes when you door is open or your lights are left on is happening when we are driving down the road for no reason. The "bing" sound...and a light will flash on the...
go around and open and close all doors first including the tail gate. see if this corrects the problem. if not its possible the switch in one of the doors is going bad. if this doesnt help eliminate the problem by disconnecting one door switch at a time till you find the one being effected. hope this helps
Jan 31, 2011 | 2002 Ford Explorer
I have a 2000 ford Taurus that makes a whooshing noise when the wheels are in motion. What's wrong with my car now!!
If you have the type or wheels that you can look past to see the brake rotors, you will see rust. This rust will form more where the brake pads have set for a couple of days. When you start rolling the rust will be rubbing the brake pads until it wears off. This makes the sound.
This is normal for todays cars. It can be minimized slightly with Ceramic pads, but the real culprit is the steel in the Rotors. Dry roads and everyday use will eliminate the problem until we get a wet spell again.
May 22, 2010 | 2000 Ford Taurus
How do I eliminate of vastly reduce the road
put carpet down and fill the door panels with insulation and put some sort of insulation(sleeping bag) in the hatch on the floor. take some housing insulation board, comes in 4X8 sheets and cut an fitting piece to place behind the rear seats in the hatch.
Apr 19, 2009 | 1998 Honda Civic
Hissing noise
This is mostly caused by the speakers being turned up causing feedback. If you use headphones it should eliminate this problem.
Hope this helps. Bud
Dec 01, 2008 | Logitech QuickCam Webcam
Problem with geting sound out of my external speakers.
adjust your sound or check the volume on the speakers itself, or try adjusting the sound on the computer, and check the sound card
Sep 02, 2008 | Audio Players & Recorders
Car stereo im trying to build
I guess the question you need to ask yourself then is how much money are you willing to spend? If you are looking for a sound quality system then it WILL cost a lot more than a DB all out BASS system. The system that you have picked out isn't a bad one but as with all systems this in only half the story. You will need to have it installed well to get the best from the speakers that you have chosen too. If you want to have the stealth look in the cabin then it's pretty simple, but you will not get the best sound quality or should I say imaging as the OEM locations usually are no good for this.
I would suggest that even though you keep things looking stealthy in the cabin apply sound deadening to the doors as Asian cars are generally quite tinny unlike German cars. This will make a big difference in terms of overall sound quality & help keep out the road noise so you can hear every little detail of your personalised system.
Dec 25, 2007 | Car Audio & Video
Pioneer AVIC-D3 Car DVD Player Logo
243 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
