Question about Asrock K7VM4 Motherboard
Video failure I believe my K7VM4 to be failing due to age. After a while running the display will disappear, but I can tell that everything else inside the box is running. Have swapped display adapters (nVidia FX5200) but result is the same. Do you have a recommended or suggested "drop-in" replacement? for this micro ATX board. I have read that the K7S41GX is good. I really don't want to have to change components and spend hours (days) configuring. Thanks Peter Rawlins
  • prawlins Jul 22, 2008
    Hi Dileep,
    Sorry I have been a while to reply.
    In actual fact I have tried swapping video display adapter cards, but the symptoms are the same. My question comes down to this really : which is the easiest microATX M.B. to replace what I believe to be an aging ASRock K7VM4? I think th ASRock K7S41GX looks suitable but would like other peoples opinions.
    Thanks
    prawlins
  • 983 Answers
Hi.....
you will face this kind of display problem if the video adapter IC(integrated circuit ) is dead or if it is getting over heated in the short time in the motherboard ...
you just have to do is you must replace that video adapter IC ...
just contact the motherboard technician and get that IC replaced ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 16, 2008
The time display has gone blank. When I switch on temp dial the red oven light flickers. When I switch on fan dial nothing happens
Assure full power is available to the unit(220 volts-not 2 times the same 100 volts). Depending on the model, and age of the unit, the circuit board behind the clock is failing or has failed. The timer board directs timed power for the oven, shows the times, and may have other features. Any elements are usually directly controlled by the knobs without going thru the timer board. When the timer display disappears and stays blank no matter what you do, even turning the breaker off and then on again , then power thru the board has failed. This could be caused by mass failure of the board(burned out-burned parts-vaporized parts) right down to a couple simple components that have failed due to age and don't pass the power onto the circuit.. High voltage is present and any troubleshooting should be done by a competent person for that task. Be safe.
Apr 27, 2015 | Ovens
I have dell d600.when i switch on my laptop.on dell logo wnd windows logo it displays vertical lines blinking some dots.but when windows xp starts the lines disappears.and when i run a video then again it...
that the problem goes away when the pc heats up for a couple minutes would lead me to believe that the problem is a bad connection. in short driver issues and hardware failure rarely if ever fixes itself after 10 min of running, where a loose connection might tighten up as it expands in response to the` heat.
Oct 20, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Samsung 920nw when it warms display disappears & a few
Most common cause of the failed monitors are bad caps in the power supply, if it is about two years old, I would open it up and look for bad caps first, then look for any burnt parts, post back so we can guide you further, see failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Samsung SyncMaster 920NW Monitor
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
W910i. 'operation failed' - display. executing games or applications this message appears. Also walkman function failure until i uploaded latest firmware from sony ericcson website, however,...
I had that problem for ages with my W910i. Took it to the Vodafone shop and the help desk didn't seem suprise at the problems I told him about my phone. He said to download the upgrades from the site. Did all that and my phone is like brand new now, everything works, the internet is far better and there's new applications!
It works brilliantly now!
Mar 11, 2008 | Cell Phones
Graphics proble wihle working in 3D modeling software
in BIOS recheck your graphics MB capability. In windows, recheck everything in performance, let's be real that's an old board. try updating your graphics driver.
Sep 07, 2007 | Asrock K7VM4 Motherboard
Asrock K7VM4 Motherboard Logo
125 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
