If you have the strong virus you can not not open flash drive.
Follow step>Go another PC which is running well, If all the hidden file and protected system file can see in that PC think that is well in condition. But please don't connect the usb pen drive.Now you stop the autorun .Follow all the instruction.
How will you confirm?
Follow the steep.
Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT and an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
If , still there are no hidden file in drive C:
Think your computer has affected by serious virus because to protect the systemfile
microsoft manege all sysy file as hidden.
When you can see all hidden file think Ok .
If your another PC is well, after examine all the steep, do all the steep now
>start>program>accessories>system tools >system restore >set earlier date. If you have the strong virus you can not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task manager>run type ms config >enter, it will be open windows>run type gpedit.msc> enter ,it will be show.>run type regedit enter ,it will be open .think your another pc run in ok condition. Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
Now auto run program off. you can see and delete easily all the hidden unnecessary file .auto run file. From hare you can insert the pen drive and delete unnecessary file or format.Now you can format or open your pen drive.
Hope it will help you.
