Question about HP Media Center m7060n PC Desktop
Hp media center power
My hp media center pc will not turn on. When i plug it in the power source light blinks in the back of the computer. I get no responce from the computer. The computer was working fine 2 days ago and has moved about 5 feet when we painted.
  • Lilybugs Jul 13, 2008
    my HP media center m7160 will not turn on. Green light on the back blinks slowly with no power source and when the plug is connected the light blinks faster. I tried with no power source holding the power button on for 15 - 20 seconds and then plugging the cord in and trying to turn PC on but no results from that.
  • 43 Answers
Hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Posted on Jul 22, 2008
We had a power outage and now my HP m1264n desktop computer will not start. The green light on the back is flashing, but nothing happens when I press the power button on the front. Could it be my power...
the green light on the power supply but it dosnt relay to the mother board,the first item I would nbe concerned with is that the power supply that is,unplug your computer open up the access panel on the tower,the largest plug from the power supply,going to the motherboard unplug it . the plug has a release on it pinch inward and pull up at the sametime this will relaese it, now plug in your computer to the wall power and if your power supply has a switch on it turn it on,also make sure the 240 110 volt switch it's a slide switch on the power supply is on 110 volts if your not in europeits 110 here in the usa, if the light fails to blink or even turn on its the fuse in the power supply,if the light comes on blinking the power supply needs more attention if the light stays on full the problem lyes beyond the power supplyI would guess the fuse is the problem,now youll find two of them within the case of the power supply hope this helps.
Dec 18, 2010 | HP Media Center m1264n - 3.0Ghz 1024MB...
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Had a power outage, now my HP media center will not turn on.
Sometimes when this happens the motherboard shorts out. You will need to replace that.
Jan 22, 2010 | HP Media Center Photosmart PC (M7160N) PC...
When trying to turn on HP Media Center desktop, I press start button then button starts to blink green and orange and computer will not boot. I unplug CPU and start button stays lit for atleast 30 seconds.
this issue has been taken up on this forum, with a plethora of solutions. This is a power issue. Easiest solution, unplug the computer, wait 5 minutes, plug it back in, wait 2 minutes, then turn it on. That will fix your problem 90% of the time. If not, here is a bunch of solutions:
http://www.fixya.com/support/t350366-power_green_light_flashing_hp_desk_top
Dec 27, 2009 | HP Media Center m7250n (ED842AA) PC...
HP Media Center PC m1195c will not turn on,has green blinking light on back near power plug.
Remove your main power cable on the back of your PC. Let it sit idle for an hour and then try and power it up again. The memory in the BIOS should clear up and power back on.
Jul 25, 2009 | HP Computers & Internet
Computer will not boot up after i disconnect power
If the component with the blinking green light is on your network card, it has nothing to do with your problem, but does demonstrate that *********** board is NOT fried or there would be no voltage available to make the light blink.
Something on your board may be fried, but not the entire board.
Unit needs board level service, so obtain an RMA, if available and submit the unit for bench testing and service.
Mar 29, 2009 | HP Media Center m1195c (PJ475AA) PC...
Hpmedia center will not turn on
Go to the following website to view information on your problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=434549
Hope you find what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Jan 30, 2009 | HP Media Center M370N (DM163A#ABA) PC...
HP Media Center m7060n PC Desktop Logo
352 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
