Question about Maytag Kitchen Ranges
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and the oven light works. I had recently cleaned the oven - don't know if that has anything to do with it. I had a repairman look at it and was told it needs a new igniter. I don't see how that would affect the clock and timer. Also, aren't there separate igniters for the oven and broiler?
  • 254 Answers
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Posted on Jul 12, 2008
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Kenmore gas range, burners are working fine. Stove is not working, front panel, clock/timer..panel is off...
Hello there:
Please read the entire solution i have provided it doe4s cover things that you have said has already been checked but there is more to it
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician. The clock stopped The non-electronic clocks on gas range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Sep 28, 2010 | Kenmore 78733 Gas Kitchen Range
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working
check its fuses, might be one of them has blown/ open.
Jul 30, 2008 | GE JBP71 Electric Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
Oct 09, 2007 | GE JBP71 Electric Kitchen Range
Kitchen Ranges Logo
243 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
