Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
I have a Hotpoint WD64 which runs through the wash cycle without heating the water. I've checked the heating element which is fine. It has what appears to be a temperature sensor which fits in a hole between the element terminals. This appears to be open circuit.
  • 958 Answers
Hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Posted on Jul 11, 2008
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Cold feed only
i don't see why not, you only be able to wash in cold water and i hope u have a drain and power in that room.
Dec 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
253 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
