Question about Linksys Ultra RangePlus Wireless Routr Router
Cannot connect to the internet with my laptop
I bought a Linksys wireless-G Broadband router model # WRT54G2 and I am trying to use my laptop. the laptop tells me that there is a loose network connection, but I checked both cables to the modem and to the router and computer and they are fine, I also switched them out just in case but had the same error.
Please Help
  • 2 more comments
  • Lrhamps5 Aug 07, 2008
    I followed the setup wizard steps 1-4. Step 4 says to plug in the router, which I've done, and the green lights on the router light up. But, the wizard says the router is not plugged in. Also, with the router set up and plugged in, I can't get internet on my pc. Is it possible my pc is blocking the router and I need to unlock some security on my pc? I know I have all the cables hooked up correctly, and my laptop is capable of picking up internet signals.
  • LostFrames08 Sep 27, 2008
    same thing essentially happened to me: My DSL connection works fine directly connecting modem to computer. When I put the router in between modem and computer, router set-up would not complete.: it continually hangs up on step 4. I got error message 321 when connected to port 1 on the router. I re-tried on port 4 and got same thing. This could be a problem with the DSL modem--may need to be in PPPoE vice DHCP: but my ISP's instructions on configuring the modem have not worked so far. Anyone have any ideas?
  • Anonymous Dec 18, 2008
    Yikes, so much upgrading the router. Using RCA245R cable modem, Linksys WRT54G2 v1, Cox as an ISP and a mix of wired and wireless PC's running XP Pro SP3. Able to connect any direct wired PC to cable modem but adding Linksys router in results in constant modem resets. Have reset both modem and router back to factory default several times with a restart order of modem, router and pc with waits between each. Occasionally modem will stay up for about 40 minutes and then crash. Several days ago had blazing fast connect speeds and then everything went down again as soon as a wireless laptop hit the router. I'm stumped and Cox understandably can't help with the router.
  • Anonymous Jan 26, 2009
    my linksys notebook adaptor cannot detect an internet connection from my linkyss router. help
Most likey you will need to set MAC cloning on the new router. The MAC address should be printined on the DSL or FIOS router/modem.
I'm having the same issue, except my WRT54G2 is not getting DHCP from verizon now.
Posted on Dec 04, 2008
    Problem Solver:
  • 26 Answers
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Posted on Jul 11, 2008
5 Suggested Answers
luiskiev
  • 144 Answers
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Posted on Nov 07, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
  • 211 Answers
SOURCE: How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Posted on Jan 10, 2010
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I bought WRT54G2 router , but could not detect the broadband connection ,,,
do you have the broadband modem plugged into the wan on the router and is the cable you are using good. and also check to see if your internet is working. you should be able to connect your computer to the modem and get internet. if your broad band requires you to log on the modem before you get out you will need to connect directly to your router and set it up per the instructions.
Dec 24, 2009 | Linksys Wireless-G WRT54G Router
I have good internet signal from cable modem and laptop detects router at 46 Mbps but can't access internet wirelessly
  • Is your computer connected to the wireless router
  • If you are able to see the router, maybe you need a security code to access it.
  • disable and enable your wireless on your computer.
Do hope 1 of the above helps.
Aug 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to connect to wireless router
I need more details. Have you called linksys tech support? If linksys cannot help you try this http://technicalsupport.blog.friendster.com/
Feb 12, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Need securtiy key or passphrase for linksys to get internet
have you tried a hard reset?
or checked the 192.168,#.# ?
admininstartor
password or blank
Oct 15, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting linksys srx200
It means that the router is not yet configured properly for internet connection. Who is your internet service provider and what is the model or brand of your modem?
Aug 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Can't go on Internet with Linksys Router
log into router by entering its default web page into your browser 10.0.0.9 usually. then run tests and save.Easy
Apr 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Ultra RangePlus Wireless Routr Router Logo
389 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
