Question about ITT Night Mariner 160 Monocular
Itt night quest 150
I have a itt night quest 150 gen 2. i just obtained it and i can see fine in the dark, but i notice a darker shaded cresent shape on the right. it is not cosmetic blemishes. the right side of the tube it darker than the left. is this normal or is the tube going out. thanks
  • rangerman50 Sep 04, 2008
    I also have an itt night quest 150, and it shows a darker crescent shape in the eyepiece. I can't find any blemish, or other problem with the glass. I've cleaned the surface carefully, but I have not gotten rid of the shadow.
Sounds like the image tube may have shifted in its mounting? This sometimes occures when the night vision has been subjected to an impact or dropped sometime in its life. Repair is not cost effective for a 150 / Gen2.
Posted on Sep 26, 2008
Not sure if this applies, but this is on the Morovision site: http://www.morovision.com/faqs.htm Because of the manufacturing processes, all night vision image tubes will have different cosmetics such as small spots or specs, photocathode coloring, or a chicken wire effect from the microchannel plate. Most cosmetics are only noticed during viewing in high light situations such as viewing with the daylight filter on in a lit room. Most cosmetic blemishes are not noticeable during normal nighttime operation but may still be seen to some degree in certain situations. These cosmetics in no way effect the performance of the image tube and do not decrease the ability to perform nighttime tasks.
Posted on Sep 24, 2008
I need a manual for a itt vision quest 5001 or i need to know how to reset it.
Great looking product - GEN3 - much better than the Night Owl stuff from 5 yrs ago.
Not sure if you can obtain a manual for a product that is restricted by ITAR regulations. I thought these were MIL use .
The only thing I can find is a SPEC link like :-- Operators Manual. CALL US TODAY AT: Toll Free 1-800-424-8222 http://www.morovision.com/pdf/2006/ITT_NQ5001.pdf
A reset is usually any method of disconnecting the power supply for at least 3-5 secs so the sensor can discharge into ground. Just removing the batteries should do this. -- Ray
Jan 22, 2011 | ITT Night Quest 5001 Goggles
PVS14 will not power up. You can see the IR light up, but the night vision itself will not come on.
Hello, it could just three thing wrong here; no battery power to oscillator and voltage multiplier or the image intensifier is bad. You can test the oscillator and voltage multiplier by powering it up with 3 volt battery and touch the output end with your finger. You'll get a little shock, but they is very little current, especially in the micr-amps region.
You'll need to send the tube to two distributor of ITT Litton image tubes, Morrison Optic Co, and the other ????? can remember. GB....stewibison
Nov 23, 2010 | ITT Night Quest PVS-14 Monocular
I have an NEPVS-14 that was left on while facing
this is not much to go on???? i gess you have found out its not working by now,,,try changing the batterys? these scopes only have a life span of about1500 hours after that there dead they are "bright light protected" so leaving it switch on in daylight should have just knocked the batterys out,,,
Nov 15, 2009 | Quest ITT Night PVS-14 Gen 3 Night Vision...
Hi, I have the night mariner 250 model (Gen 2?), when turning it on it shows the low battery indicator (red) light flashing and then switches off after approx. 6 seconds. It does this all the time, even...
The problem could be caused by dirty battery contacts or faulty capacitor on power supply board.
I suggest cleaning the battery terminals with iso-propanol alcohol and fine emery paper.
If this doesn't work, you really should take it to a repair/service centre.
Mar 23, 2009 | ITT Optics
Does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Mar 13, 2009 | ITT Night Quest 220
Installed new batteries and it still will not work
replace with new battery and retest. this unit has a itt 2nd gen tube with an encapsuled power supply next to the tube the power supply is probably faulty the two sides of this nv are also siliconed together making it a difficult unit to dissasemble for testing but i have done this model before
Apr 29, 2008 | ITT Night Mariner 160 Monocular
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Just purchased a ITT Night Quest 160 G3
AE OPTICS in Texas repairs these. Find them online.May be under AEO also. Contact is Dana Prather.
Tim Mallory
Dec 14, 2007 | ITT Optics
ITT Night Mariner 160 Monocular Logo
757 people viewed this question
Top ITT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an ITT Optic Expert? Answer questions, earn points and help others
