Question about Epson Stylus CX9400 Photo Printer
Error 0495 - Receiving Faxes
This is a bizarre fax machine. I have the ability to send faxes 100% of the time, and I've also received faxes. Problem is that the receiving end is not consistent. Sometimes the machine receives, sometimes it doesn't. I print out the error log and it say error 0495, I can't figure it out.
    Problem Solver:
  • 6 Answers
Might be a problem with speed of the fax. See related question.
Posted on Aug 11, 2008
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Intermittently, the confirmation page on the fax says the fax failed (didn't go thru) but it actually did. Why is this? The confirmation page is printing false results, indicating the fax failed to go...
This is because some faxes don't have Error Correction Mode capabilities.
If there's a slight distortion on the line, the receiving machine (without ECM) receives a fax with some minor errors. And even though for a human eye the resulting fax page is perfectly readable, for the machine, that thinks only zeros and ones, there was an error detected in the data, and hence the trasmission failed.
Faxes with ECM when they detect an error, ask the sending fax to re-send the last portion of data, and this way can bring the transmission to a 100% successful end.
So the only thing you can do is ask your recipients to upgrade their fax machines to an ECM-capable model :)
Oct 29, 2009 | Canon Office Equipment & Supplies
Not receiving faxes. It will send but not receive
have someone send you a fax. When the machine rings, press START. if this works you are set to MANUAL instead of AUTO
Sep 17, 2009 | Brother IntelliFAX 5750e Laser Fax
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Epson Stylus CX9400 Photo Printer Logo
943 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
