Question about QuarkXPress 4.1 for mac
Making changes to an old file - save - error -43 ( file not found )
Made changes to an old file -  save -  error -43 ( file not found ) but it sits there on the desktop looking at me so i can see its there ( not lost )
  • 1 more comment
  • tonyryder Jul 13, 2008
    i thought i'd spotted a solution -
    http://www.pc-error-repair.org/error/lib...">Fix Error 432 Minute Error 43 Fix. Free Download. 100% Guaranteed.
    PC-Error-Repair.org
    see on the right
    but no, this does not work as i have a mac -
    i'm lost in a fog of overload -
    where do i see a solution ? -
    how do i find the troubleshooting forum ?
    is there a troubleshooting forum ?
    New Friend:
Save under "save as" from the toolbar and rename the document
Posted on Jun 24, 2013
  • 108 Answers
Just downsave the document to one lower version and it should work
Posted on Jun 16, 2009
How Do I Fix Error Code 43 in Windows 7?
This is probably one of the most frustrating and "generic" error codes reported by Windows. When I say "generic", I'm referring to the fact that Windows is basically telling you that a hardware device on your PC is well... not working. (Gee, Thanks!)
Error code 43 is reported anytime Windows does not recognize a device - whether it be a USB port, Hard drive, video card or any other piece of hardware connected to your computer.
You will usually see an error message like this:
"Error Code 43: Windows has stopped this device because it has reported problems"
And if you look at the hardware under Windows device manager, you will see something like this:
NOTE: The hardware device above is only an example. It could be any device on your computer that is reporting error 43.
What Causes Error 43? 95% of the time, error code 43 means that a device driver is either missing, corrupt, outdated (so Windows problems communicating properly with the hardware), or the hardware is faulty and needs to be replaced.
Device drivers can become damaged or corrupt over time, and most users will eventually experience a driver error. Installing and removing software and hardware can cause conflicts in the registry and can alter driver communication.
Sometimes you can bypass the error temporarily such as removing the device from the motherboard and reseating it, removing the power cord from the power supply and restarting your computer after a few minutes, etc. However, theses are temporary and will not fix the actual problem.
Solution For Fixing Error Code 43 Messages The first thing of course is to make sure your device driver is up to date. I have provided two ways to accomplish this below:
Option #1: Update your drivers automatically (the easy way)
If your not that technical and don't want to hassle with trying to locate the correct device drivers from your PC's manufacturer and then go through the process of uninstalling and re-installing your drivers manually, then you should run a free scan with a recommended driver tool.
This software will match and download the correct drivers you need. It's safe and saves a lot of time keeping your PC updated.
Option #2: Update your drivers manually (the technical way)
If you consider yourself pretty technical and feel confident making changes to your system, then follow the steps below:
Step #1 - Uninstall the current driver:
First, you need to uninstall the current driver...
  • Click "Start > Run" and type "sysdm.cpl" in the text box and press ENTER
  • Open the "Hardware" tab on the System Properties dialog box, then click on "Device Manager"
  • Double click "Device Type", then click on the hardware device that is reporting Error 43
  • Next, go to the "Driver" tab and click "Uninstall" to uninstall the device driver completely
Step #2 - Locate the correct driver:
After you have uninstalled the driver, visit the manufacturers website and locate the newest driver for your device. You can usually find the latest driver under the technical support or driver section of the company's website.
Step #3 - Download the driver:
Download the driver and save it to your computer. It will most likely be compressed in a .ZIP file, or an executable file (.EXE).
Step #4 - Install the new driver on your PC:
Extract the .ZIP file or double-click the .EXE and install the driver.
Step #5 - Reboot your PC:
If you uninstalled the old driver and installed the correct new driver, it should fix the communication problem between Windows and your hardware device, eliminating the error 43 message. If not, you might want to install the faulty device on another PC and see if it works correctly.
If you continue to experience problems then most likely the device itself is damaged and needs to be replaced.
Good luck.
Semper Fi,
Z
Feb 19, 2018 | Computers & Internet
Tip
How to edit Media Center Recordings
Easiest FREE way I've found to edit Recordings made in Windows Media Center is done using Windows Live Movie Maker (Part of the Windows Live Essentials Free Downloads)
I have found that there is some technique involved in making successful edits of the recording.
  1. Open the recording you want to edit in Movie Maker, click save and name the save file what you wish (This file just stores your edit markers and makes no changes to the original recording)
  2. Since most recordings have some overlap, you first need to find the actual beginning and end of the recording, under tools, mark the start and end points using the buttons labeled as such. Click SAVE
  3. Editing the commercials is done in a similiar manner. Browse thru the recording to the start point of the commercial, under tools, click the SPLIT button, then browse to the end of the commercial segment, click split again. (This separates a the commercial portion from the rest of the recording) Right click the commercial segment, Click Delete on the drop down menu and that commercial is deleted (Note the run time is adjusted to the removal point) Click save and repeat on all other commercials.
  4. Once editing is complete, you should have about 22 minutes for a half hour show or 43 minutes for an hour show. Click Save
  5. Here is where I drove myself crazy till I learned the trick. Once edits are saved, CLOSE movie Maker. I don't know exactly why, but I spent a week learning that no matter what I did, 90% of the time when I tried to create movie, movie maker would LOCK UP. Trial and error eventually proved that if I made my edits, then Saved and closed Movie Maker. The re-opened Movie Maker and opened the edit file, that I could then Create Movie successfully every attempt. Click File, Create Movie, and choose your format. (I use widescreen) Saving process is slow, about the length of the show or 1% per minute. This creates a .WMV file about 1/3 the size of the original.
  6. If you want to compress the file even more you can use an encoder to convert the file from WMV to a compressed format (I prefer AVI) I use SUPER © from Erightsoft.com
on Aug 11, 2010 | Computers & Internet
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Help!...While 'collecting for output' an error -43(file not found). All images are OK. Not sure what to do...
Check under Usage and check that all the images are valid and updated. If these are correct, check whether the images are quark EPS files, if they are place the files in illustrator or photoshop (DO NOT OPEN THEM) and then save them in the appropriate format. Before you do this ensure that you have copies of these files .
Hope this helps.
Nov 03, 2009 | QuarkXPress
Deleting
Error -43 is the common "File Not Found" error.  This can also mean a folder is not found. (A Google search for "macintosh error codes" returns a complete list from Apple at http://support.apple.com/kb/HT1618.)  I don't know why it would say this unless the files really don't exist.
Dragging an item to the Trash doesn't usually require a password unless you are not the owner of the item.  This can occur when copying items from another user's account, for example.
Try selecting all of the items that you want to delete, hold down the Option key, and choose Show Inspector from the File menu.  In the Sharing & Permissions area at the bottom of the Inspector window, verify that you have permission to delete the files.  If not, click the lock icon, type an administrator's username and password, then change the Privilege to Read & Write (you might have to use the + icon to add yourself to the list before changing anything).
Close the Inspector window and delete the items.  This should do the trick.
Feb 25, 2009 | Apple Mac 10.5.1 Desktop
Quark for mac
Just downsave the document and it would take care of the issue as well
Jul 13, 2008 | QuarkXPress 4.1 for mac
"File not found" error message when I try to use a saved network settings file to configure my Microsoft Broadband Networking hardware
CAUSE This issue may occur if you change the file name from the default file name "Networksettings.xml". RESOLUTION To resolve this issue, do not click My settings are on a floppy on the Where are your network settings located? page in the Microsoft Broadband Networking Setup Wizard. Instead, click My settings are in a file available from this computer, locate the floppy disk drive, and then click your configuration file.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
QuarkXPress 4.1 for mac Logo
698 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Michael Galve
Michael Galve
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
