Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Installing printer When I put the disk in to install the printer, it will not because of the paperport. What do I need to do. I have been to the brother solution center and I don't understand what to do there.
  • hotpink175 Jul 12, 2008
    I am following the directions that came with the printer....no it is not plugged in before trying to install. Thanks for your suggestion.
  • 2,794 Answers
Make sure the printer isn't plugged into the printer before doing it.
Posted on Jul 12, 2008
Free software paperport
Sir/Madam
PaperPort installs a PaperPort Black and White Image driver and a PaperPort Color Image driver. These drivers allow you to import documents onto the PaperPort desktop via the print feature.
If one or both of the drivers are missing, follow the steps listed below to run the PaperPort repair program. This program will re-install the drivers:
  1. Open the Control Panel.
2.Open "Add or Remove Programs".
3.Locate and select PaperPort. Click the "Change" button.
4.When the PaperPort InstallShield wizard appears click NEXT.
5.Select "Repair" and click NEXT.
6.Click "Install" to begin the repair process.
7.When the installation is completed a window stating "InstallShield Wizard Completed" will appear. Click FINISH.
8 The repair process is now complete and the drivers will now be installed.
If your question was not answered, please Go To Below URL for Brother Printer Troubleshoot,
OR
If You Still Need Assistance Then Follow US For On :
Brother Printer Support
Feb 03, 2014 | Brother MFC-290C Printer
I have a Xerox Phaser 3100MFP. It will print, but will not scan. Help...
have you installed scaner driver WIA SCAN DRIVER
and have you installed paperport v11
if not install paperport v11 and wia scan driver from"http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3100MFP&Xlang=en_IN&Xcntry=IND"
Aug 21, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
It keeps saying that the scanning device is Out of memory/exceeds limits? is this a paperport problem or my scanner? and why all of a sudden? My scanner is a Canon MX860 and has been working great -...
"...till now"
So... what changed? did you install some new software that consumes a lot of resources?
Some update?
Changed something in the resolution? (higher = more memory needed)
check the disk space too, maybe the pagefile is larger than usual.
or, re-install the scanner driver, and PaperPort just to clear things out.
Sep 17, 2009 | ScanSoft PaperPort Deluxe 9...
Cant scan via network?
You cannot use the paperport software to network scan. The paperport software is looking for a driver that is not installed. Network scanning for this printer is basically just file sharing. You initiate the scan at the printer itself. It scans the image and puts it on your computer. After it is there, you can use paperport to convert it to text if need be.
Jan 15, 2009 | Dell 1815dn All-In-One Laser Printer
I am trying to install Paperport 9.0, which I once had on another computer. Each time the Wizard stops installation with an 'Paperport 9.0 Inside Information' with an error sign: Internal Error 2723 New...
Unfortunately, the newer version of PaperPort has left the traces in the registry. You can try to manually search and edit the registry or try one of the PaperPort Removal Tool options.
Backup your computer before trying the following steps. To edit the registry, make sure that you are using the account with Administrator privileges. Click Start and choose Run (for Windows versions 7 and down). For Windows 8, 8.1 and 10, click the Start button and type run. (With Windows 10, you can also right click on the Start button and choose Run.) Type in regedit. Use the Edit > Find command to search for PaperPort keys. Export the key to a file with the File > Export command. Then delete the key. You will need to restart the computer after closing regedit to load the new registry.
Alternatively, try one of the Nuance PaperPort removal tools. See http://nuance.custhelp.com/app/answers/list//p/26/kw/What%20are%20you%20looking%20for?#s=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 . for links to the removal tool for various versions of PaperPort. Note: if you have a CD with PaperPort 9, it will have the PaperPort 9 removal tool in a sub-directory. You will need administrator privileges to run the removal tools. This is a much safer option than regedit for most users. However, you need to know which version of PaperPort was installed. I'd try the PaperPort 9 unistall tool first. The last time PaperPort was installed, the system probably checked for updates and some patches were applied.
I hope this helps. You may want to clear the temporary files as well by using a Disk cleanup option. From File Explorer, right click on the hard drive icon and choose Properties. In the General tab, you will see an option for Disk Cleanup. After doing a basic cleanup, consider going back and press the Clean Up System Files button to get rid of more temporary files.
Jan 20, 2018 | Office Equipment & Supplies
Brother DCP-130C printer
download the whole mfl-pro suite drivers at www.brother.com choose your country and your dcp. After downloading install. You cant run paperport due to the fact that it is part of the cd. But all needed drivers will be installed..
Apr 08, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
Feb 28, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
