Ping pong ball in washing machine pipe
Filter pump was blocked with piece of clothing. On removing item, found what looks like ping pong ball in pipe, should it be there?
Yes it is ment to be in there, ive searched the internet and everyone having the same problem with a ping pong type thing, do not remove, as it used as a valve for the drain.
Posted on Jun 20, 2010
  • lxdms1
    lxdms1 Feb 15, 2014
    how do you put it back? could illustrate how to assemble it back because im confused if its before or after the rubber oring? thank ypu
  • 5,911 Answers
Yes...many washers use these little white balls as valves for the drain and recirc cycles for their pumps. A notable model that uses this feature is the Calypso.
Posted on Jul 11, 2008
My washing machine isnt loading with water
hi i think you mean a ball looks like a ping pong ball it doesent go in pump it sits in filter i allways take them out anyway its up to you strange about water check wires to valves were water pipes fit unplug 1st
Jan 12, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Whirlpool AWM6120 - small ping pong size ball found in black drain part????
The ball is supposed to be there. It should be in the drain hose at the bottom of the drum. It is part of the eco system of the washer. In the service manual its called an "eco lock"
Oct 13, 2012 | Whirlpool AWM6120 Front Load Washer
How much does a ping pong ball normally cost?
A high quality (3 stars) ping pong ball costs around $1. These balls last for along time. Cheaper, low quality ping pong balls can be purchases for much less,but they will not last you a long time.
Aug 05, 2012 | Sport & Outdoor - Others
Hotpoint WD 640. The machine is not fully draining after washing or drying. Any help?
The reason for this is almost certainly because the empty pump filter is partially blocked. Unfortunately, our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attacking from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. You will probably find lint, coins and junk inside. Clean, replace the ball, reassemble. All should be ok
Jun 21, 2011 | Hotpoint Aquarius WD640 Front Load...
My front load doesn't want to drain and spin the water out
There is a float valve at the bottom of the drum, it may be blocked- I had the same problem and found a sock in it when I took off the hose to inspect the valve. The valve looks like a captive ping pong ball. Good luck!
Aug 11, 2010 | GE Washing Machines
Found lots of fluff from a previous wash. Next wash the machine failed to empty. Did persist & a trickle of water arrived, machine is now almost empty of water, least enough open the door. Possible...
To clean pump you will need to unplug machine, at rear using screwdriver remove the panel at bottom of machine. depending on fitting of clip holding pipe onto your pump, use suitable tool to remove the clip. You can now remove the pipe from the pump. check inside the pump also.If you need to remove the tub end of this pipe there is what is like a ping pong ball within the pipe. Make sure you refit this as it acts as a non return for the water.
Mar 15, 2010 | Hotpoint First Edition WMA22 Front Load...
Leaves in water
Check pipes are not blocked, to do this while you have water in machine,remove outlet pipe from drain, and place into a bowl so it is below the tub.If water does not come out then pipe is blocked. Whichever you need to do the following.
1 unplug machine, and remove the rear panel at the bottom, using a screwdriver.
2 If no water came out from pipe then directly below tub is a black pipe, this will need to be removed using fitting either grips or a screwdriver, depending on what fitting retains pipe to the tub.As you remove the pipe be carefull not to loose the ball inside pipe. This is like a ping pong ball.You can now check pipe.
If you did get waterr out from pipe at stage 1 then remove other end of this pipe, from the pump only. Then tilt machine and view under pump to see what holds it in place. Normally 2 scews. Remove these and lift pump away, be carefull of the 2 wires that go to pump.You can now check pump is clear. If it is then chances are you need a new pump. This will cost around £10.00 but you will need to use the front part from old pump.When refitting ensure pipes are fitted correct and you have no leaks. This is fairly easy to do yourself, just take time and look where screws are fitted to pump casing. I am sure you will do this no problem, so good luck. PS. most shops will charge around £45. if pump is blocked and anything from £45-£60 to fit a it is worth doing it yourself.Also you dont need a genuine hotpoint pump, just ask for an Askol pump.
Mar 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Does my hotpoint washing machine aquarius wd64 have a filter
if your hotpoint has no obvious filter ( small flap on front ) its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.
pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully andd make sure its all back together as before.
Not easy but the blocked filter causes so many hotpoint issues. Its a pain the way they have built it inside the machine rather than making it user friendly.
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Zanussi washing machine
You dont say what your original problem was but the ball is there to act like a float.
Sep 01, 2009 | Zanussi FC1200W Front Load Washer
Whirlpool awm 337 does not complete a wash cycle
There is either something stuck in the water pump (rogue sock) - front of machine - bottom right, open the flap, remove the plug and check (p.s. it will drop lots of water).
OR, underneath the machine - where the exit pipe from the drum, you will see a split ring holding on the rubber waste pipe. Behind that is a ping pong ball and rubber seal. Socks and the like do collect here.
It's happened about 6 times to me, have got used to fixing it.
Aug 11, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,322 people viewed this question
Top Washing Machines Experts
