Clothes are soaking wet because it doesnt spin.
The most common problem is the lid switch. Make sure you hear a distinct click when you close the lid, if not, then that's the problem. The lid switches are made of 2 plastic pieces(usually) and they tend to seperate. I've fixed many by removing the switch enough to get at it(power unplugged of course), and using epoxy around the edges to hold the switch housing together, and putting a tie wrap tightly around the switch so it will never happen again. I believe this will hold better than a new(still plastic and still glued) lid switch.
Posted on Jul 11, 2008
  • 95 Answers
Check the door switch for broken or damaged wires. get a jumper wire to go from one wire to the other wire on the switch. If the jumper wire is connected and the washer spins out, then the door switch needs to be replaced
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
The spin cycle doesnt seem to be working - clothes are coming out soaking wet - what could it be
Overloading, see if ur spin cycle wok ok by doing a empty load and watching it
Oct 26, 2009 | EuroTech EWF150 Front Load Washer
The clothes are coming out soaking wet.
just cause pump moves doesnt mean its working
Jun 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
