Question about HP Officejet 5610 All-In-One InkJet Printer
My fax machine gets a busy signal for every time i dial long distance number. is there any settings i need to change
  • 234 Answers
Have you checked with your telephone provide that you have access to dail long distance calls.
Good Luck
Posted on Aug 31, 2008
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
Canon ImageRunner 1025if won't fax to #s, only email
Try to connect simple phone to fax line and try to dial a number of fax that you are calling from machine.If the line is ok then do the next:
press MENU and # ( service mode) with cursors go to clear, ok, clear all and ok.Turn off and on.
If that doesnt help call service.
Be carefull: the tel. line to fax machine must be connected in L slot, not in small picture of telephone.
Jun 15, 2010 | Canon Imagerunner 1025IF Grayscale Copier
Every time I try to fax I get a busy signal. I tried to fax several places and I get the same thing cannot be completed as dial.
dial those numbers from a regular phone and listen for fax tones. If you hear a busy signal, then they are busy.
Jan 14, 2010 | Brother FAX-575 Plain Paper Thermal
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Hp L7580 fax machine
set up the fax driver in windows printers and faxes menu with the calling card prompts. you can use commas between sets of numbers for 2 second pauses. such as (example) 9,,1800callmci,,,2,,3,,cardnumber,,,4digitpin,,3685551212, - in this fashion, you can edit the fax number here before sending the fax.
Sep 24, 2008 | HP Pavilion dv6000z Notebook
Fax
I'm not sure where your machine is attached. But are you plugged into a pabx or switchboard system? If you are then I think you may either need an access code for either outside like or long distance calls. The other thing is the setting on the machine. Can I assume it is on tone dialing? If it is set on pulse, then it won't work. I'm assuming you are in the U.S. that uses almost all tone dialing. Hope this helps.
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
