My 02 Pathfinder just lost its back lights and instrument panel lights. Checked fuses and they are good. Think it is a fusible link but don't know where it is or if there is one. Can someone help with that? I should also say that it was connected to a trailer when the lights went out.Thanks
You said it has a trailer harness. These harnesses are known for corroding internally and causing shorts. Try to disconnect the harness from vehicle wiring and replace the fuse (left panel next to steering wheel (change cup) or under hood) not sure without having vehicle in front of me. This is most likely the cause of your issue. Hope this helps.
Some times when you get a short circuit. It will burn out a tail light bulb. With the bulb burnt out you don’ have a complete circuit. First, replace you tail light bulbs. If that doesn’t work. Check to see if you have a ground wire come off.
Thanks for the help
