Question about SanDisk Sansa Clip MP3 Player
Nothing happens when ON switch is pressed.
My player won't engage when I press the "on" switch. I don't think the diplay is out, because when I plug it into my computer I can see the "connecting" message. Did I use the hold button too much? I've had this MP3 less than 2 months!!
  • joester11 Jul 15, 2008
    the player is charging but when the player is removed it won't turn on
Have you tried recharging the MP3 player? I too have a Sansa Clip which I play in the car so I don't often see the "battery low' message, but when I recharge it the MP3 player works again. I understand it takes longer to recharge from the computer so I bought a recharger I plug into the wall.
Posted on Jul 11, 2008
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
L 115 19 HP 42" JOHN DEERE RIDING TRACTOR WON"t start
There are several safety switches such as under the seat, blade engagement, neutral switch....all must be in working order and the lever in the proper position to get fire to the starter.
Oct 18, 2014 | John Deere Garden
Compaq Presario SR1050NX Won't Turn On. . .
You're typing like you have been working tirelessly on the problem.
In fact there is no user name, lol!
Okay.....relax...........just ease back, and put your hands behind your head, and close your eyes.............think about clouds floating across in the sky.
Better?
Alright.
Your Power Supply is bad. Weak voltage power rail.
Replace it.
Don't think so? Cool.
That's what I'm here for. To teach.
Have a multimeter?
A) If ALL of the LED's were on they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
(Older Intel Pentium I, II, and III, uses less than 51 Watts. Some older AMD's do also)
Primer:
You press the Power On button. The plastic assembly of the Power On button in turn presses against a Power On switch,
http://www.directron.com/atxswitch.html
The Power On switch is a Momentary Contact Switch.
When briefly closed the Power On switch completes a circuit.
The Soft Power On circuit.
When the Power Supply is plugged into power, there is a constant 5 Volts (DC) present.
The 5 Volt Standby power.
Pressing the Power On button redirects the 5 Volt Standby power, in the Power Supply. This 'excites' the Power Supply, and turns it on.
(Soft Power On circuit)
The first chipset (I.C.) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(WinXP and Win7 are two examples of an O/S)
Primer over.
1) http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&lang=en&lc=en&product=405454&
2) http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00595250&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=405454
FOLLOW Anti-Static Precautions
2a) http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3433073&prodTypeId=12454&objectID=c01358034
(Yes, I know. Slightly different computer case. Principles still apply)
3) Don't think you will be hearing any BIOS Beep Codes, because there isn't enough power, lol!
For additional questions please post in a Comment.
Regards,
joecoolvette
(If Power Supply power were dynamite, your Power Supply wouldn't have enough power to bl-ow it's nose)
Aug 28, 2012 | Compaq Presario SR1050NX (DW257A) PC...
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Torro ride on wont start. Won't even kick over. Its like there has been a safety switched flipped as nothing is happening, when before I stopped for a moment it was working fine.
Insure you don't have deck engaged . There is a safety switch under the seat you can jumper it .If it is seat switch you will need to replace it.
Feb 04, 2012 | Briggs & Stratton Garden
My sony nwz e444 simply stopped working. As I took it out of my bag i obviously pressed a button, and the screen switched on, I plugged the charging cable into the device, the screen went black, then when...
Try to connect it again to your computer and while it is connected. Press the reset button on the mp3 player using a paper-clip. It should do the trick.
Sep 29, 2010 | Audio Players & Recorders
I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Dec 04, 2009 | Lasonic DVF-982 Portable DVD Player...
94 Sonoma 4x4 won;t lock into 4WD.
yea its not shifting again like before ? sounds like your transfer case solonoid has possably gone bad again .. these are a sometimes dont work item .. It is what shifts the transfer case into gear and it might be a little worn or weathered and not letting the switch kick it in gear all the way from the N position. thanks Jerry holler if you need more.
Feb 05, 2009 | 1994 GMC Sonoma
Wont turn on
Make sure the button on the left side that says on-hold-off is in the off position, then try turning it on by pressing and holding down the play/pause circle button on the front of the mp3 player.
Dec 19, 2007 | GPX MW3837 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
116 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
