Question about HP LaserJet 2300 Printer
HP Laserjet 2300: Prints only one copy
Can only get printer to print one copy even when stating on print dialogue box that i require 50 copies. Any help appreciated ...
    Problem Solver:
  • 10 Answers
Can you print the configuration page or selftest?
Posted on Oct 16, 2008
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
I have an HP color Laserjet 3700 attached via USB to Windows 7. It prints 1 copy successfully. When I try to print 2 or more copies it tries to select paper from tray 1 (which doesn't exist) and then...
To Disable Mopier Mode: Windows 7
01. Click the start button.
02. Click Devices and Printers.
03. Right click your Printer.
04. Select Printer Properties.
05. Click the Device Settings Tab.
06. Scroll down to the bottom. If necessary, expand Installable Options.
07. Click on Mopier Mode.
08. Select Disable in the selection box that appears.
09. Click Apply.
Mopier Mode should now be disabled and you should now get multiple copies.
I hope this helps
I II
Jan 10, 2018 | HP LaserJet 5si mopier Printer
Unable to store job at printer
Your print buffer is full in your hard drive.
Remove programs you don't use
Defrag the Hard Drive
Delete Temporary files in System Tools
Jun 20, 2010 | HP LaserJet 2420 Printer
Printer is squeeking when it prints pages - does
New Toner Cartridge stop usung Copy, use HP
Nov 11, 2009 | HP LaserJet 2300 Printer
Double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
Apr 21, 2009 | HP LaserJet 4350 Printer
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
HP Laserjet 2300 printing 5 copies
Friend,
There shouldn't be any need for a parallel-to-USB device, since your printer has both ports - and you could use ONE of the ports for printing. One, since two ports does NOT mean that the printer can serve two PCs simultaneously. On startup, it determines which port is active and "forgets" the other.
So I would have gone for either a parallel cable (IEEE 1284 standard, no longer than 10 feet) or a USB cable, running the cable directly from PC to printer.
If there's a need for several users to access this printer, I would either have shared it from my computer (where it's physically attached) to the other users in the network - or, purchased a jetDirect network card for the printer. With a JetDirect card the printer is accessible for all users over the network regardless of which computer is switched on.
Hope this clarifies and gives an answer to your question.
//Al
Mar 10, 2009 | HP LaserJet 2300d Printer
LASERJET 3030 PRINTS ONLY 1 COPY VISTA 64
Well go to file and click on Print... this will bring up a list of settings for your printer as well as the list of printers. There you should see a box that says number of copies.
Dec 03, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 2300 Printer Logo
531 people viewed this question
Ben Johnson
