Question about Optoma H30 Multimedia Projector
Color problem hi, i have a similar problem with my dlp hp v6311, but in my case the red gone green an green gone red, wich part do you clean, how do you clean, please if you can help me i will be really happy, thanks and sorry for my bad english
The part to clean is the sensor that wraps around the colour wheel or some thing on it's axle.
This sensor identifies when the colour wheel has made a revolution and syncs the video output to the right segment in the colour wheel so only the red image is displayed when the colourwheel is filtering red, etc...
If the sensor gets dirty it will not be able to tell exactly where the colourwheel is, and in my case started to report a segment off.
Consider this before you take your machine apart.. I live in New York City, and this area is rather dusty.. I've had my projector for 2 years running pretty constantly, so it was pretty dusty. I mention this because there are other possible causes to this problem. It could be an electronic issue.
There were three things that convinced me it was a colour wheel issue : 1) The problem appeared slowly over the period of about 2 weeks.. First it started flickering, and then all of a sudden it would switch back and forth.. 2) The color white was fine. In fact, the image was fine, just some colors were switched. I could even fix the image by adjusting the hue in my video.. 3) My machine was full of dust..
I don't know about the HP projectors, but this is the best I can do to describe how to locate the colour wheel...
If you take the bulb out of your projector, you'll probably see part of it.. The first thing wherever the bulb shines into is probably the colorwheel (or a protective cover). In my machine there is no way to access it from the bulb housing, so I had to take the entire case apart.
From there you can clearly see how the bulb shines through the colourwheel, and then then light enters a closed chamber (sealed, I assume, from dust).
If you are not able to locate the colorwheel after this, maybe take some pictures with the case apart and send them to me.. I'll look for a manual online in the meantime..
Also, I'd be happy to talk to you over skype to get more detail.
Nate
Posted on Jul 15, 2008
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
Nov 28, 2015 | Mitsubishi WD Televison & Video
I cannot print a document in red without the left side fading and turning yellow instead of red.
Hi !! that is something called laser scanner contamination, behind the magenta catridge there is a little piece of glass wich is the laser scanner. clean the glass run at least 3 cleaning modes and then sent a test page and see if it gets fixed.
if not take the printer to a service center to make a deeper cleaning or in the worst case scenario to replace the lase scanner This is a link will help you find a local Hp Authorized repair center with your zipcode : http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jul 11, 2010 | HP Color LaserJet 2600n Printer
Have just replaced Magenta toner cartridge (HP own). Red is now orange and colours seem faded. Any suggestions
Jul 08, 2010 | HP Color LaserJet 2600n Printer
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
Picture mostly green
In that case does this color problem occur on all inputs? If not then please make sure that the connections, especially the red connector, are clean and tight
Mar 16, 2009 | JVC AV-27D303 27" TV
Color shifting
this common to dlp projectors! THe DLP wheel has a problem.it has lost its alignement
the best way to solve this is to gt a new dlp wheel replacement
Feb 08, 2009 | Sharp XR-1S Notevision DLP Projector, 800...
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Optoma H30 Multimedia Projector Logo
142 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
