The light on my projection television remains on for a series of 9 flashes, then a pause, and continues with this pattern. The televsion never turns on or off. I have a sony large projection television, SCC-M37C-A, KP-51WS520. It is only 3.5 years old. Thank you.
G board failier . The board can be repaired or replaced. Repair is cheaper but this is something that has to be done by service tech. Could be big $$$ depending on what has to be done. As a slim chance try unpluging the TV then plug it back in and hope for the best. if you have the skill here is the fix
Resolder D6116 & D6117 (Surface Mount) REPLACE D6301 (Do not just resolder D6301 REPLACE IT) Can use ECG116 (1N4004) ALL On G Board
I have a RCA M50WH74S it will work fine for about 45 seconds to 1 min then it will shut down and...
(More)
I have a RCA M50WH74S it will work fine for about 45 seconds to 1 min then it will shut down and start flashing 5 times and it will come back on do the same thing all over. thanks any help
Hi, I bought an Alba CDVB4 and when i use the remote to change the channel on the set top box it...
(More)
Hi, I bought an Alba CDVB4 and when i use the remote to change the channel on the set top box it actually turns the channel over on the tele not the box? Thanks Mark
hi got a humax pvr & panasonic 32" lcd tv (both new )occasionaly the two units do not...
(More)
hi got a humax pvr & panasonic 32" lcd tv (both new )occasionaly the two units do not connect.I select hdmi 1 to watch the pvr &and it seem as the tv does not reconize the pvr.or it there is no info on screenjust like it locks up.has anyone else had this sotrt of problem and is there a cure for it
