Question about Magic Chef CER3740 Electric Kitchen Range
F1 Keeps flashing and beeping
What can I do - it's driving us crazy? Sometimes the touch pad works - sometimes it keeps beeping F1 & doesn't work. The elements are fine.
  • 117 Answers
Replace the touch pad
Posted on Jul 19, 2008
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
May 11, 2011 | Maytag Ovens
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
I have a tappan range that keeps getting F1/F3 in on the display panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
Keeps beeping and displaying F1
Hi clnee,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Sep 26, 2009 | Magic Chef 31000 Gas Kitchen Range
F1-8 code timer # 1 keeps going off on
good day,
hope this link below will solve your problem.
kitchen appliances
Dec 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Magic Chef CER3740 Electric Kitchen Range Logo
178 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
