I have an Onyx 15" LCD TV Combi SW1536LD. On switch-on I cannot reselect which mode I wish, in that, the TV defaults to the DVD setting, when I do request TV setting the TV does not recognise the signal from the remote control. I believe the remote control is at fault, but have you recorded faults with this particular model before?
  • 42 Answers
This user manual should help!
Posted on Jan 14, 2008
SOURCE: Change TV to AV mode so as to receive signal from DVD recorder
facing simillar problem:(
Posted on Jun 14, 2008
  • 417 Answers
Its Needs repair its in the main circuit board
Posted on Jul 08, 2008
  • 1269 Answers
SOURCE: Philips LCD HDTV Model 32PF5521D/12
Try to do a hard reset. Unplug it for several hours like 2-3 hours then plug it back in. If that didn't fix the problem, there's an internal component that you need to check on the circuit board like a burned capacitor. Check the fuse and the power supply. If you can't do it, you need to contact a tv repair tech.
Posted on Sep 06, 2008
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
I have 19"dvd combi which goes over to dvd for no reason then goes back to tv. have checked for stuck buttons on remote but seems ok. any ideas?
Check for any strucked button/s at front panel of the TV. If all are found OK. try a reset to this set and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 11, 2015 | Televison & Video
Logik L19dvdb11 tv/dvd problem.when selecting dvd screen display says no signal. Have tried switching on/off and reselecting input to dvd
Is the DVD player turned on when you select DVD for the TV ?
If not, there will not be a signal to detect.
Jun 07, 2014 | LG 32LD550 32 in. LCD HDTV
My 46" Samsung LCD 630 works perfectly until a
Until a ?
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 18, 2017 | Samsung LN46A630 LCD TV
I purchased the Lt37Hvs on Aug31,2006. The DVD player and the TV have always been connected by an HDMI cable. Last night the HDMI stopped working. I pulled the connectors on each end to clean and...
Check to see if the DVD has a setting to change it's Output... ie: Can you select, HDMI, RCA, Component? via the DVD? If so then reselect the correct one, perhaps Component is the "Default" output?
Jan 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Tv/dvd combi - dvd read problems
No it is not worthy, you will spend around $100, but brand new combo 13'' cost $80 and DVD starts from $22. You can use an external one.
Dec 02, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung 15" ltn1535
Hey mcca,
In many cases, blue screens on TV's can be the result of the TV being in the wrong video mode or another device (like an attached VCR) being on the wrong station.
First, I would suggest testing to make sure that your TV is in the correct video mode and station. Depending on how many devices are directly connected you to your TV, you may need to cycle through one or two video mode settings using your remote control before the DVD menu can be displayed. Typically this can be done by pressing the "Menu" or "Input" button on most remote controls, but you may wish to refer to your owner's manual for instructions how to do so with your specific model TV. In some cases, the primary video input station is even set to channel 3 or 4 by default.
If you are sure that the TV is on the right input setting (and your DVD player is connected to a VCR), I would next suggest making sure that your VCR is on the right channel. Many VCR's will also require that the channel be set on 3 or 4 in order to display any images being sent through them by a secondary device, like a DVD player or video game console. Additionally, it may even be necessary to change the input setting from "TV" to "VCR" to display signals from an attached device. Again, you would need to refer to your owner's manual documentation for specific instructions.
Lastly, if you use an RF modulator or video signal switch for any devices in your home theater, you may want to make sure that they are on the correct settings.
Hope this helps you out.
Go Ahead. Use Us.
May 28, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
Tv and dvd combi
There is no switch [TV\DVD] ?
Usually, when u turn off the TV, it should goto DEFAULT, which would be the TV. Do u have an antenna connected to the TV. Some TV go blank [deaf & dumb] when there is no signal to TV. If you cannot get the TV portion on, then I would suggest the u have an electronic switch [DVD is off, it will goto tv] that is shorted in DVD position. Is there a button that has no markings ?[you know, rubbed off by touching it so much]
touch EVERY button two times [one for on, and one for off] except the ON\OFF button !!
May 12, 2008 | Televison & Video
Jan 13, 2008 | Televison & Video
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
