Weiser Lock Powerbolt 1000 Lock Logo
Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Locked out of house. After pressing code I hear a long beep bur no bolt movement. How can I get in my house??
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Nov 05, 2011
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489428
Points
1500
Why is my Powerbolt beeping?
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Good luck--and please provide feedback if this helps!
Forgot code to securam keypad
Try pressing 111111, that should let you open the safe
If you want to change the combination code follow this steps:
• Press 111111 and leave it pressed down untill you hear 4 beeps in total, then press number 3 once (that should erase the code you had previously)
• Again, press 111111 and leave it pressed until you hear 4 beeps in total, then press number 1 once. (That should put the SecuRam in lock process.
• Now press 000000. Input once 123456 (you’ll here 2 beeps, now input your desired code, it will beep twice, again input your desired code until it beeps 2 times. (If it beeps 3 times means code wasnt accepted. Try again)
• That is all!!
Baldes locked up
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
5helpful
Blades locked up
When I lock my key sedona 2005EX, with remote, dont hear the beep
Press the lock button once to lock then press and hold to beep the horn. Kind of have to press twice.
Locking
1 st press top left button and then quickly press *(star button) u r key pad will be locked...
if u want to lock u r phone with any security code....u can do it by phone setting /security settings/
bur remember u r code no
default code no for nokis 12345.
DONT FORGET TO VOTE FOR ME MAN.
regards
Top Weiser Lock Locks & Locksmithing Experts
Sean Wright
Sean Wright
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
