Question about Texas Instruments TI-83 Plus Calculator
Some times the Keys won't display
This started yesterday. First I thought it was battery, then I changed the battery. The problem continued. The numbers keys inparticular won't display most of the times.
Buy a new calculator
Posted on Sep 12, 2008
Hi i bought a vw beetle was running fine the last few days. I went to drive it yesterday and it wont start the immobiliser is showing its not flashing tho. My step dad replaced the car keys battery the day...
My immobiliser keeps flashing until I put the key in the ignition and then it stops. Normally changing key batteries has a period that if the battery is changed inside that time (say 5 minutes) then the key program will not loose memory Run fault codes to see if there is a problem in the electronics. Otherwise you may have to take the car to the dealer to have the key reprogrammed to the cpu in the car
Sep 28, 2013 | Cars & Trucks
Cant unlock car
You need to replace the car battery.
May 06, 2013 | 2009 Toyota Corolla
Hi all,I have a Ford focus 2004 tdci 1.8 and the immobiliser intermittently won't turn off,I've tried both keys and its still won't start.kind regards Dean
Ford products are sensitive to changes in Battery voltage. The system views low Voltage as an attempted theft and makes the Alarm go off.
Remove the Battery, return it with a full charge or new Battery. Some other symptoms would be slow cranking or clicking like a dead battery. The Antitheft reduces starter Voltage to around 7 Volts making starting nearly impossible.
Please rate my info. If all else fails, the Identity in the car memory may no longer match the identity on the car keys. You would need to have a Dealer rematch the keys to the car.
Dec 11, 2012 | Cars & Trucks
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
When I go to turn on the radio it just reads "safe" and won't work or play anything. AT first i thought it was a battery issue but the battery has been charged and works great yet the radio...
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of Audi radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Jun 07, 2011 | 1988 Audi 80
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
Start up screen won`t change.
Had same problem when loading the latest Touch IT ROM from xda-developers.
Switch Phone Off.
Press and hold the 2 keys on the left and right under the screen, then press the power button.
Blue and white screen displayed. Slide out keyboard,
Press R to continue with Reset or X to Cancel.
Jun 14, 2010 | Sony Ericsson XPERIA X1 Smartphone
2002 Hyundai Santa Fe won't Start
have you checked the crankshaft sensor?
Jan 21, 2009 | 2002 Hyundai Santa Fe
Texas Instruments TI-83 Plus Calculator Logo
48 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
