Tdoes not lighthe dlp lamp - Televison & Video
    Problem Solver:
  • 17 Answers
Before you do anything check if the lamp looks ok visually.
Soon after putting power ,you should hear the color wheel spinning at high speed then the ballast should start the lamp.If the lamp still does not light then check the 300 volts dc at the ballast.If is missing check power supply.if color wheel is spinning and 300 volts at the ballast is ok but the lamp does not light up then the problem may easily be the lamp.
Note - If the problem is other than the ballast or the lamp then the repair would be very expensive.check the above first and if necessery contact me again.
Posted on Jul 19, 2008
    Sergeant:
  • 280 Answers
The lamp is bad or if you replaced the lamp... make sure you have the door in-place... the is a door switch and if you don't have the door closed well the lamp won't come on
Posted on Jul 18, 2008
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Tip
How long does a DLP lamp last?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How long does a DLP lamp last?
The most DLP Television last in between 1000 and 2000 hours this is whit the original lamp and depending on your brand.
Example the Philips lamp last between 6000 to 8000 hours and Osram like 4000 to 6000 hours usually the brand
Some lamps might last only 500 hours while others may last 3000 hours of life so check brand. And keep it clean of dust.
on Jan 27, 2010 | Televison & Video
DLP television picture not clear (blurry) and dark.
Hello
If picture is dark in DLP TVs, its lamp should be taken care of. In some lamps, the reflecting side coating of lamp will be bubbled, preventing sufficiant light to fall on DLP chip. Replace the lamp if necessary. Check it first, taking it ouside. OK.
Apr 15, 2011 | Mitsubishi Televison & Video
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
DLP Lamp Replacement
in the rear their is a section were you can uncrew and replace the lamp. be sure that its unplug from the ac outlet and you wear a glove so you wont touch the lamp.
Apr 01, 2008 | Televison & Video
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Televison & Video Logo
291 people viewed this question
Top Televison & Video Experts
