Health & Beauty Logo
Posted on Jan 08, 2011
Our screen shows V3.76D-VNW, what do we do? - Health & Beauty
jacqueline vasquez
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 03, 2012
jacqueline vasquez
Contributor
Level 1:
Answers
Questions
0
Helped
454
Points
0
I have a yellow black oxygen/pluse reader by choicemmed i changed the battary nowit reads V3.76D-VNW
Screen shows nodata
Screen shows "no data found". ' Relias Connect
https://rlconnect.reliaslearning.com/thread/4943
Screen shows "no data found". 2153112 Sep 2, 2015 8:53 AM. Screen shows "no data found". 20 Views; Categories: Senior Care - Assisted Living, Home Health ...
Charter.net No Data Message on a Gray Screen
www.charter.net/support/tv/no-data-gray-screen/
Charter CommunicationsTV with grey screen displaying words - No Data. If you are seeing the words "No Data" on a gray screen on your TV, follow these troubleshooting steps.
Why does screen shows NO DATA even after tracks have ...
https://sony-paa-pa-en-web--paa.custhelp.com/.../why-does-screen-shows...
If the unit holds no data transferred from SonicStage, the screen shows NO DATA. User can playback the tracks recorded with the unit from HOME screen - Rec ...
Netflix on my laptop shows part screen
See if you have a "full screen" option on Netflix's window.
Happy New Year.
Topbarhive
I have a PB6200 BenQ projector. When the computer starts up it shows the BenQ and then shows the windows computer startup screen until it finally fully boots up. Then the projector does not show what is...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
Where is the constant factor key on a Canon P170-DH?
How to do constant multiplication or division on the Canon P170-DH calculator
This process actually requires fewer keystrokes than other calculators. Basically, just do the first problem
and then do the next items with just the next number and the EQUAL key. For example,
*** Constant Multiplication ***
2 (multiply key)
10 (= key)
(The answer 20 shows on the screen. Note, the 2 is still stored as a constant without doing anything, just continue)
4 = (shows the answer 8 on the screen)
20 = (shows the answer 40 on the screen)
100 = (shows the answer 200 on the screen)
*** Constant Division ***
10 (divided by key)
2 =
(shows the answer 5 on the screen, the 2 is still stored as a constant without doing anything, just continue)
100 = (shows the answer 50 on the screen)
500 = (shows the answer 250 on the screen)
4 = (shows the answer 2 on the screen)
No display on screen
It's either the backlight lamp or screen inverter is busted. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Boot up.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the screen inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 • Cameras
2helpful
Cannot find the constant key for multiplication
This process actually requires fewer keystrokes than most other calculators. Basically, just do the first problem
2 (multiply key)
10 (= key)
10 (divided by key)
2 =
Also note! There is no K visible on the screen to indicate a constant is set.
Display issues
Could you show a picture of the screen?. The problem is probable the LCD screen or cabling.
You can get the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
