Question about Samsung CLP-510 Laser Printer
Cancel button is stuck
Hello:
During a printing job I pressed the cancel button. It is now stuck down : I think I pressed too hard.
Now both red and green lights are flashing (the red was flashing before because the toner cartridge has been low for a while)
Your assistance would be appreciated before my husband pulls the machine apart....!
    President:
  • Samsung Master
  • 1,314 Answers
Can you take a paperclip or something else like a nail file and gently pry the button up by sliding the small object beside it?
Posted on Jul 11, 2008
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
Canon mf4150 - Cannot cancel a print job
Hello, I know you wrote this seven months ago, but if you are still having issue, you have to press the "system Monitor" button on the printer. then press ok for print jobs, then the right and left arrors to cancel
It is aggrivating how canon put no shortcut button on the printer to cancel this.
It is under chapter 3 in teh advanced guide you can get at the link below on canon's site.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4150#BrochuresAndManuals
nice day.
May 18, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
2015 network printer
Please perform the following:
Unplug the network Cable:
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
    If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Network reset A network reset changes all network system parameters in NVRAM to the factory defaults. During the network-reset process, all button presses are ignored.
Use the following procedure to perform a network reset.
  2. Simultaneously Press and hold the Go and Job Cancel buttons.
  3. Turn on the printer and continue to hold the Go and Job Cancel buttons for approximately 10 seconds, but no longer than 20 seconds. During this process, the Attention light turns on.
  4. Release the Go and Job Cancel buttons. The Attention , Ready , and Go lights begin cycling from front to back. After the network-reset process is complete, the device returns to the ready state.
    If the Attention and Ready lights illuminate before you release the Job Cancel button, start again at step 1.
Now plug in the network cable and then wait for 5 mins.
Then print a configuration page and check the IP Address.
Jul 29, 2008 | HP LaserJet P2015dn Printer
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Samsung CLP-510 Laser Printer Logo
63 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
