Question about Whirlpool Duet GHW9150P Front Load Washer
Fins where can i get new ones
I have had two fins fall off, (one has been misplaced) We do not know how to put these one or where to buy them. My clothes are getting holes from the metal clips.
Thanks
  • hawaii0712 Jul 12, 2008
    thanks so much, i just realized my model number is ghw9400pwo, will the part number be the same. When I search under that model number I can't find the part!
  • 5,911 Answers
These are called drum baffles. They can be found at repairclinic.com. Type in your model number and search for item #1058883. A set of three of them goes for about $34. It is cheaper to buy them in this quantity as a single baffle ranges in price from $22 to $34, depending on which website you go to. The baffles should have installation instructions with them. Of not, let me know. I hope this helps you.
Posted on Jul 11, 2008
  • Jeff Rockwell
    Jeff Rockwell Jul 12, 2008
    The part number is the same. I typed in your model number at repairclinic.com and found a link to it on page 3.
Every time I defrost my fridge, a fin falls off. How do I put them back on or can I?
I have seen fins fall off and I do not know how to put them back on. I would suggest contacting
USA
SERVICE OFFICE
Dometic Corporation
2320 Industrial Parkway
Elkhart, IN 46516
574-294-2511
and getting a factory trained technician to address your problem. There may be some adhesive you could use but this problem needs to be addressed by the factory. This may be a product defect and if still withing warranty, could be fixed by the parent company. You will need the model number and serial number when dealing with the parent company.
Mar 22, 2015 | Dometic RM2652 Refrigerator
One of my dryer fins fell off how to get it back on
Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
Feb 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
We have misplaced the car charger for our PE701 AudioVox Eddie Bauer portable DVD player and I don't know where to find a replacement, can you help?
U tries places like Radio Shack,Walmart,Target,Kmart and Best Buy stores yets?Try websites like Partstore.com,Amazon.com,Ebay.com should able to buy a new one or a very closed compatible one.
Aug 16, 2011 | Eddie Bauer Televison & Video
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Nov 11, 2009 | Computers & Internet
Two weeks after buying the watch it just stopped the jeweler thinks it might be that the second hand is getting stuck
Depends on the kind of watch. If it is a quartz watch it could be the battery.
If it is a mechanical it has a more serious problem. A new watch most likely will not have a problem with a hand touching unless the watch has taken a great fall and the hands are jarred enough to misplace them. Of course this kind of fall will cause other damage.
Seriously, most jewelers don't know what a watch is let alone how it works or what could be wrong with it. Have a watchmaker look at it and they can give you real information.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Watches
How do you change the mineral absorption pad?
The pad is very easy to replace. Simply remove the water tank. The mineral pad floats in the hot water reservoir. Pull out the old one and discard if it has begun to break down. That's all their is to it.
I hope this helps.
Jan 01, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
I have a Roper RAX7245BWO that the top of the agitator is loose and doesn't agitate. I know I need to replace the cam dogs. What I can't figure out is how to get the inner cover (part #20 on the agitator...
take the disp out, remove the inter cover, take out the 7/16 screw, pull agit up from bottom to take out of washer, set on floor, put feet on bottom of agit and hold top fins and pull up hard and quick, will come apart, after putting new dogs hold agit upside down to put back together or dogs will keep falling out and put back together / please remember to leave a rating / have a good day.
Nov 27, 2008 | Washing Machines
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Dehumidifier
water in system got in maby or bad condosor in it these so cheap best u go buy new one instead trying to fix yours find the right parts would be hassel cheaper to buy new ok
Mar 16, 2008 | Whirlpool AD40DSL Dehumidifier
Whirlpool Duet GHW9150P Front Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal De
