Question about Denon Audio Players & Recorders
Need to identify blown resister r-531 on main amplifier board
  • 27 Answers
How do you know it is specifically that resistor? I suppose you have schematics or something that is telling you R531 may be an issue. If a resistor is blown it will likely be black or discolored somehow.
Posted on Jul 23, 2008
My acer aspire v5-531 will not turn on and no lights at all when connected to tested power supply
kindly remove the battery n check with power, if possible get checked the power connector of the power supply, with a multi meter, if its ok then its a main board issue. u have to change the main board
Jul 16, 2016 | Acer Aspire Laptop PC V5-531-4636
Where is the fuse in a xr1220 mixer.
which fuse?? main fuse? output fuses?
if the main fuse has blown & the device simply won't power up, replacing it will merely result in another blown fuse - you need to take it to someone who can repair the units' power supply
output fuses blow when speaker wires are shorted, or speakers fail short - they're on the main circuit board, but seeing you're asking, i'd suggest you don't open the unit, but take it to someone who knows what they're doing
Feb 21, 2015 | Peavey Audio Players & Recorders
One possibility is that the power-on speaker protection delay is stuck on. The most common cause of this is a shorted transistor in one of the power amplifier channels. In that case, you will need to replace the speaker driver transistors in that channel. I don't have service information on your particular model; it may use power amplifier modules rather than individual transistors.
The tricky part is identifying the amplifier power and speaker output terminals to test for this problem. To find a shorted output transistor, you need to measure the resistance between the output of each channel and the plus, then the minus power supply connections. There is a relay between the amplifier output and each speaker terminal on the back; this relay is turned off by the speaker protection circuit, so you can't measure from the speaker terminals. If you have a fried transistor, one of the tests will show a resistance of a fraction of an ohm. A good transistor will have a very high resistance or read open. This will be the case whether you have modular amplifiers or discrete transistors.
If you see a blown fuse, that is a strong indication that you do have a fried transistor. Sometimes the speaker protector circuit shuts down fast enough to save the fuse, but not always.
Apr 27, 2011 | Sony Audio Players & Recorders
Power would not turn on when i turn it on it says hello then protec then power turns off
this happens when one of the amplifier chips on the main board is blown. player's main board needs to be repaired or replaced.
Nov 27, 2009 | Samsung DVD-Homecinema-Sound-Package ...
It keeps blowing fuses, so I checked out the circuit board and it turns out 2 transistors next to each other are blown as they are reading 0 resistance on the multimeter. Can someone help me find a...
Hello there:
if you go to radio shack they have all of these transistors that you will need. these are not hard to replace if you know how to use a soldering iron ok?
best regards mike
Aug 04, 2009 | Earthquake Sound PH800W.2 Car Audio...
Is it known to overheat easily? if so why is this and how can it b sorted
Amps overheat if the impedance is missmatched, if the grounding is not sufficient or if there is an internal component failure. Normally the fuse will blow to stop the amp from damaging itself, unless you are using a fuse which is too high ampage than the factory fuse, then you will be damaging your amp instead. I'd say it could be a blown transistor. If so you will need to open up the amp run a multimeter to check resistance on the transistors if it's close to 0 they are blown. Other signs could be soot on the board and any obvious damage.
Aug 02, 2009 | JBL GTO755.6 Car Audio Amplifier
I have a burned out resister which I need to replace.
R11 = 3.9 K ohm 1/4 w If Q6 burned,change by NTE5657 ( 600v)
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Nedd to identify blown resistor
how can you detect a blown resister
Jul 11, 2008 | Audio Players & Recorders
78 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
