Question about HP Compaq Presario V6000T Notebook
Pendrive My presario laptop is not able to read any pendrive. I'm using Win Vista Home Basic, when i connect a pendrive to any 3 of the USB port no drive (removal) are opened. Please help me to find a sol..........
    Problem Solver:
  • 17 Answers
Try another pendrive and see if the same is working.
PLease make sure if your pendrive is USB 2.0 compliant.
If it came with an installation CD/CVD, install the same and try.
Cheers,
Posted on Jul 20, 2008
My Transcend 500GB is not working on my Dell Inspiron 1464 Windows 7 Home Basic But other USB devices like pendrive etc works fine. Also My Transcend 500 GB works fine on other machine has Windows 7...
The chances are that the portable drive is drawing more current fom the USB port then the port can supply. The current limitations on the USB ports are controlled electronically and if anything is connectedthat attempts to draw more power then the port can safely supply, the port is shut down.
You may have to use a USB power injector which you plug into the laptop and then plug the drive into that.
Mar 08, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a emachine netbook and it say no bootable device
Failed hard drive (assuming one is installed), or could be that it has "lost" the Windows installation.
Possibly a virus, you need to reinstall windows, or hopefully, repair the installation
To do this, as this does not appear to have a DVD rom, you will need the following:
  1. A legit copy of windows (whichever is installed currently)
  2. A spare computer or preferably an external USB DVD Drive (if the latter, skip to the end)
  3. The SATA drivers for this laptop (essential if using windows xp, may not need if vista)
  4. a USB pendrive of at least 4 GB
  5. A USB Floppy drive (possibly)
  6. a copy of win to flash
http://wintoflash.com/home/en/
Uisng the spare computer, extract the contents of the Windows disc to a folder on the spare computers hard drive. Run win to flash and follow the instructions, it will build a boot copy of windows on the pendrive that you specify (it will format the pendrive also).
Copy the sata drivers to the USB floppy drive (you might get away with copying them to the same usb bootable you have just made but I doubt it)
Now, in the bios, set 1st boot to USB drive
Then boot and install, when you reach the F6 prompt, point it to the usb floppy drive and let if find the sata textmode drivers.
Its hould then find your existing windows installation and repair it
IF you ahve a USB DVD / CDROM drive, ignore the above and just install from that, you may need to use a floppy usb to install the sata drivers though
Feb 08, 2011 | Acer eMachines eM2501162 Netbook
My pendrive not detecting
hi guest welcome to the forum! 1.if u r using win 98, u have to install drivers for the same pendrive watever u r using...
2.if u r using win 2000 or xp or vista, u need not to install the pendrive,but check out tchat ur usb is enabled or whether is working properly by hanging out at the DEVICE MANAGER.
You will get a clear idea when u get on the DEVICE MANGER..
if u dont get the usb ports on DM, then u checkout for hardware trouble shooting..
all the best..
May 19, 2010 | Health & Beauty
Pendrive more than 2gb dont detect
usually 2.0 USB driver donot detect bigger capacity pendrives. so you need to install the driver for suitable capacity
Jan 15, 2010 | Vantec 1 Bay NexStar 3 USB 2.0 External...
TRANSCEND PEN DRIVE WHEN CONNECTED TO THE USB PORT POP-UP MENU DOES NOT APPEAR ON THE SCREEN PLS REPLY
There are two possible reasons either your pen drive is not functioning or the auto play is disabled.
First of all check whether the Pen Drive is listed on my computer as a removable drive. If so then do the following steps:
1) right click on the properties and select "Auto play" tab.
2) On the dropdown choose mixed content.
3) Under "Actions" select "prompt me each time to choose an action" button.
4) Apply and OK
Now remove your Pendrive and reconnect.
This should solve your problem.
If your Pendrive doesnt show up on my computer there can be two reasons. either the USB port you are connecting is faulty . try a different USB port. or your pendrive is faulty which needs replacement....
Jul 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive appear as cd drive in my computer
******Chances are that the CD drive took the drive letter of your thumb drive and it is now locked.******
Need to know what operating system you are using: Win 2000, XP, Vista. There are different tools you need to use in order to resolve this issue.
For XP (your thumb drive needs to be inserted)
Click start then run. Type "compmgmt.msc"
This will bring up the Computer Management console. From there you will see the Storage category (on the left side). Under Storage click the Disk Management sub category.
Here you will see all the file systems available to windows.
Right click on the drive in question and click the "Change drive letter and paths" sub-category. Just choose a letter that is not in use. I prefer to use 2 or 3 letters down from the current.
Now properly remove drive and re-insert.
Hope that helps.
Apr 02, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
USB PenDrive
enter the pen drive into pendrive slot then go into cantrol pannel and click on add hardwer and the pen drive show on youer computer
Nov 17, 2008 | Microsoft Windows Xp Home Edition Sp2...
HP Compaq Presario V6000T Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
