Question about Hoover Vacuums
I have a Hoover z 700 the "see manual" light keeps coming on when im using it! I cant find the manual can you help me?
  • 328 Answers
Hi (dont forget to rate this please)
Go to hoover.com website here:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Paste in the model number: U9145900 and you should be able to find a user manual for this to save (opens in PDF)
Posted on Jul 19, 2008
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
I have the hoover steam vac f5906900 and im just trying to use the detachment. I plugged in the water part but i cant get any suction. the water is spraying out that is all....help my dog **** on my bed...
Hi, The attachment hose also has to be plugged into the dirty water recovery tank. The other end of the hose which has the square plug, must go in the spot on the recovery tank where the water comes up from the floor. To do this, Remove the lid of the recovery tank, slide out the little rectangle (usually same color as the recovery tank) which is located just above the clear water channel from the floor there, and insert the square piece for the attachment hose. It should only fit in one way. Replace the lid to the tank and you should be ready to attack the ****. Good luck. Mark
Nov 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
I got a vacumn from a friend who ungraded and though i used at her home when i got it home it would not turn on when plugged in and i check everything and no use. my friend lost her manual. im in my 60's...
Hi In the UK we have similar machines but they are made by Vax. If you can't source the correct user manual from Hoover.com consider the following - it is a free download.
http://www.vax.co.uk/downloads/pdf/vzl-60156016_v2_(brushbar).pdf
The Vax Mach 5 and Hoover model you have are the same other than the name. Dont forget to rate, thanks.
Feb 22, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Water keeps coming out of my hoover spin scrub
The bottom of the solution tank has a rubber stopper, if this tank is not installed just right that rubber can get caught, or damaged. Here is the manual for your machine.
http://www.hoover.com/pdfs/manuals/H3030.pdf
I hope this helps.
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
My hoover belt keeps burning when i replace it. i dont have the manual so i dont know what im doing wrong.
Probably when you close it back together, there is a piece rubbing against that you do not see right away but could maybe hear it.
Sep 26, 2008 | Hoover Vacuums
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Sep 26, 2007 | Hoover Elite U5061-900 Bagged Upright...
Vacuums Logo
120 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
