Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Dehumidifier Freezing up
By InstantLegen on Jul 11, 2008
My 3 year old GE 40 pt dehumidifier worked fine last month, but not is freezing up all the time. When it freezes up the compressor does not shut off, even though this unit has auto defrost, and the compressor/unit gets very hot. I have to manually turn it off and let it defrost. About 1/2 hour after turning it back on this happens again. Room temp is 72 deg. Humidity control set on 55%. It seems like the auto defrost is not working. What can I do to fix it?
Thanks
Same Problem
Apr 26, 2009
-   DId you buy yours at Sam's Club? Just curious- because we did and the exact same thing is happening at about the 3 year mark.  I think we will be buying a new one today as is is Spring and much needed in our basement. -   Guest
Best Solution
posted on Jul 12, 2008
Helpful)
Illeagle
Rank: Guru
Rating: 88%, 481 votes
Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Clicking on the underlined links will take you directly to that page.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Some models utilize a defrost thermostat that simply switches the compressor off and on. This can be replaced by unsnapping it from the condensor coil.
Another type uses a defrost control kit to cycle the compressor and is a little more involved in the replacement.
See Item #
878674 by clicking the link below
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=878674&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 05, 2009
Very Helpful)
TLRTS123
Rank: Apprentice
Rating: 100%, 1 votes
Your dehumidifiers are LOW on freon. Over time, small leaks will occur and the coils will freeze. Take your units to a qualified repair shop (central air, or furnace) and recharge the freon.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
I dont see the filter. I took out bucket but there is not visable filter in unit.
Answer
have power and it runs. fan will not go on.
Answer
I have a Sunbeam model 2411 humidifier. Cleaning instructions say to remove the housing, but I... (More)
Describe your Dehumidifiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
in , PA
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
