Question about Whirlpool Calypso GVW9959K Top Load Washer
No water? My washer fills with water but it seems like its just enough to get clothes wet not enough to wash. any advise?
  • 246 Answers
Calypso's use very little water. The only way to change how much goes in is by the pressure switch located in the console. It tells the machine when to stop filling. A replacment is availible from a local appliance parts provider or online from the manufactures web site. But I can tell you from experience, when you fill one of these machines without a load of laundry inside, it won't even cover the top of the bottom plate. Even with clothes in it, there is still not very much that will go in. More water will be added durring the course of the cycle as the clothes absorb the water (there is less pressure going to the switch and it tells it to fill again). But again, the pressure switch determines how much water goes in. You can access it by removing the 1/4" screws in the back of the console. It is the white circle with the clear tube going to it. Yes, there are 2 that look almost identical. One is for incoming water level and 1 is for recirculation water. The matching part number will be stamped on top of the one you are replacing. Just remove the wire connector, pull the clear tube off, and press the tab while rotating the switch assembly. It will come right out. Instalation is just the reverse.
Posted on Jul 12, 2008
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
Washer seems to need more water.
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Feb 01, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
LG Intellowaster 2.08ft^3 (Fill with water while washing? yes/no)
no you wont see much water at all and make sure 2 to 3 tbsp of he detergent also
Jul 06, 2009 | LG Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Whirlpool Calypso GVW9959K Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De
