Question about Whirlpool Duet GHW9150P Front Load Washer
I get a dl and F code.
Has run great for 4 years now. We did have the power go out so I did just unplug it for 5 min. I thought that may have done the trick but it didn't. It beeps and flashes dl and F.
  • 5,911 Answers
"Fdl" is a door lock error. In most cases, you will have to replace the door latch assembly. Please click on the following link for an explanation of how to change the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
The part can be located at searspartsdirect.com by typing in your COMPLETE model number and looking under the "Door and Latch Parts" heading for item number 7. The part number is 8181700.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 11, 2008
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My music creator 4 wont let me register my product
HI ^^
take this latest version
download the full version of Cakewalk Music Creator 5
Release Name: CAKEWALK.MUSIC.CREATOR.V5-ADDICTION
Download:
http://hotfile.com/dl/7508024/76ecddc/cmcv5.part1.rar.html
http://hotfile.com/dl/7508027/7bd05b2/cmcv5.part2.rar.html
http://hotfile.com/dl/7508026/7b1d1bb/cmcv5.part3.rar.html
http://hotfile.com/dl/7508028/4f36d59/cmcv5.part4.rar.html
Any troubles just let me know
plz rate it FIXYA ;)
Jun 26, 2009 | Cakewalk Music Creator 4
Chevy s10 pickup 1995 4cyl stantard 2wd
power loss therse days could be electrical, could be needing to take in more cold air, check the air intakes
Jun 05, 2009 | 2005 Nissan Altima
89 regal won,t start but after 5 or 10 min. runs great
sounds like your fuel pump is going out. One thought might be that the fuel filter is causing enough resistance to over heat the pump. I would check the fule pressure to determine a free flow of fuel.
May 01, 2009 | 1990 Buick Reatta
93 montero quit running
Did you run out of oil?
Apr 26, 2009 | 1993 Mitsubishi Montero
Washer is flashing f and dl and isnt draining correct.
This is joyce
First of all unplug unit from wall to reset. leave unpluged for 1 min. then replug back
check to see if you lines are not crimped where your water goes out of machine. if this dont work to get your codes go to web site whirlpool.com and type in your model # and download your documents and find your codes and then you can go from their, I have the same thing you have and believe me I have had my share of problems with mine, but nothing like you are having, thank goodness I had exstended warranty for 5 years, it is exspensive to work on these units. dont try to work on them yourself they are all high tech. if you need help finding someone to work on your unit just email me.
thanks
joyce
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
F-11
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Replace failed component.
Jun 15, 2008 | KitchenAid KHWS01PMT Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
