Question about Dell 3100cn Laser Printer
Black Line on Rt side of every printed sheet!
Black line that goes down right side of page. How do you clean this cotton pickin printer?
  • sold395 Jul 15, 2008
    I ended up having to replace the drum cartridge.
  • Anonymous Aug 08, 2008
    line down the left side of the paper
Replace the drum cartridge.
Posted on Oct 07, 2008
    Problem Solver:
  • 7 Answers
I don't know if this will help but I was getting smears on the right side of the paper where there was no printing. I came acrossed this and it worked for me. Open up the front cover and lift the top cover and remove the drum cartridge. Then with cartridge out remove the left and right screw on the side of the cartridge. This will give the drum belt room without hitting the cartridge case. The cartridges plastic was not formed well.
Posted on Jul 15, 2008
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Copies have black roller marks on the right side of each page, getting darker each time. I can print a single sheet, wait, it print again, wait~roller lines aren't as bad, but still present
I could be wrong, but I think it's in the toner cartridge. The drum - the roller that the image is formed on - has a soft, plastic blade rubbing against it to clean off excess toner after each print. If a clump of toner gets stuck under the blade, a line is printed down the page where that part of the drum isn't cleaned as well. Between prints, the drum keeps turning, and may be able to clean itself better than in a single revolution. It's a theory, anyway.
Pull out your toner cartridge and look at the drum to see if there's a black line around it at one end. You can't get to the cleaning blade without risking ruining the drum and the cartridge; the cure is just to get a new cartridge. If yours is fairly new, take it back to the store that sold it to you, along with a print sample. They might exchange it.
If the drum doesn't have a line around it, you can test it by deliberately jamming the machine. It's scary, but if you've unjammed jams before, you can do it again. Start a print job, then kill the power when you think the page is right in the middle of the printer. Open the printer and remove the toner cartridge. Look for that black line on the page before it reaches the drum, between the drum and the fuser, and past the fuser. (The fuser is the pair of hot rollers that pinch the page tightly and melt the powdered image into the paper. Any part of the image that hasn't made it into the fuser is still powder and will rub off.)
If the line doesn't show up until after the hot rollers, then I was wrong about the toner cartridge, and you're looking at a fuser problem.
Mar 11, 2011 | Samsung ML-2510 Laser Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Line shows up down right side of page that was copied or Faxed
your ink wel needs cleaning, do some deep cleaning and if that dont work take your ink well out and clean it manually
Nov 11, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Dell 3100cn Laser Printer Logo
438 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
