Question about HP Color LaserJet 2600n Printer
Smudges on right ride of paper
The right side from top to bottom smudges with all colors collectively and there are small spaces without any color throught the page
  • dory 5 Jul 13, 2008
    yes I have this same problem too
    connie petrik
Want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Posted on Jul 13, 2008
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
When printing in color the right edge of paper is smuged
Inks from your printhead is deposited on right side of the soft sponge across the printhead pathway. Take a tissue paper and fold it and gently dap it dry
Nov 01, 2012 | HP PSC 1600 InkJet Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
I have a HP LaserJet 3700n. Color smudges
Its the toner cartridge that is the same color as your smudges.
Feb 25, 2010 | HP LaserJet 3700n Printer
Dell 3100cn (color printer): color smudging
Smuding typically occurs when you print on a heavier paper without changing the settings. By changing the settings to a thick paper type, the page will be send through the printer more slowly. this will likely eliminate the smudging.
Cheers.
Sep 24, 2009 | Dell 3100cn Laser Printer
Error code: color registration error and ultra-light, smudged printing on right side of paper
have you replaced all of the consumables?
drums X2 black and color
developer units X4 CMYK
transfer imaging belt X1
Fuser unit X1
if the unit has over 60k prints it will need to have these items replaced and once that is done the color registration will come back inline.
Jul 28, 2009 | Ricoh Aficio CL3500N Laser Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Smudges down left side of paper
Maybe something attached (corrector fluid or adhesive)on drum (green cylinder - don't touch it!) or more probably the fixing film on the fusing unit is damaged (probably some paper clip left over input bin, or trying to remove a paper jam with some sharp-pointed thing) If you have some other printer like this around, try with another print cartridge, if error persist , the fuser film is damaged...
Sep 07, 2007 | HP LaserJet 2420 Printer
HP Color LaserJet 2600n Printer Logo
469 people viewed this question
Ben Johnson
