Question about Samsung PCN5425R 54" Rear Projection Television
Convergence Install I installed the convergence board that I bought from the link you post for me. I installed it this past Tuesday after being away on vacation. I was excited to maybe get it working again. Once installed I ran the convergence setup and it went to 4% and stopped just as my old one. The picture was still bowed. I think maybe I got a defective part, I have sent a contact us message about it but no response. If it possible something else is bad? But I think the replacement board is bad..... Thanks
  • Samsung Master
  • 8,617 Answers
I would try sending them a email, as they are very quick to respond to emails. The parts are either new or remanufactured so I doubt very much that the board is defective you most likely have another problem most likely in the Digital convergence unit.
Posted on Jul 11, 2008
  • Sonny Berry
    Sonny Berry Jul 11, 2008
    I just talked to one of the techs over there you may want to contact them as they have been sending emails to you with the return info you requested but keeps returning your emails saying its not a valid email account. Try using another email address to leave them and they can forward the emails they have already sent . I knew there had to be a reason why you havent gotten any response, as they are known for their customer relations and support
Heating paste on convergence board
Its called thermal paste. It can be purchased from most local Radio Shack or other electronic stores. Its usually included with convergence kits so if you bought a convergence repair kit from sites like check closely in the kit for the thermal paste. Its often in small packs or tubes and can easly be overlook.
Feb 25, 2013 | Televison & Video
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
Red convergence outline
I posted this before, however it fits your situation so here are my suggestions:
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Mar 10, 2009 | JVC AV-56WP74 56" Rear Projection...
Convergence way off!
Yup, you lost convergence. The only fix is to repair/replace the convergence IC. Some techs will just replace the whole video board.
Nov 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
D52W20 Convergence
I believe that you have a defective convergence board, call tritronics or parts store with the chassis number and model number and ask for a convergence board and after you install the board set the convergence to factory set.
here is tritronics phone# 1-800-638-3328
for parts stores just go to and get the number.
good luck
it is simple just disconnect the cables and the board and install the new one(remember to disconnect the set from the power ac outlet )
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w19 convergence hell
Did you replace the convergence board or the convergence power supply board? usually one color will be a problem with the convergence board and more than one color means the convergence power supply is the problem. Ebay isnt a good place for boards as you never know if the board is good. You can get the convergence or the convergence power supply boards at the following link along with free shipping and tech support.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Sounds like the digital convergence controls is possibly the item giving you the problem, if you have already changed the convergence board. You can get a used digital convergence board at the following link, just leave them a email and state your model number and what your needing.
Jun 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Convergence board for Samsung HCL4715w
The Convergence ICs will need to be replaced , 95% of the time thats the problem they are on the sub board not the convergence board. You will need two STK392-040 ICs . you can get replacements at the following link and they will provide free installation instructions along with free on-line tech support when you install them. takes about 45 minutes. Heres the link.
Apr 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung TV model HCN5527W
The actual Convergence amp ICs not located on the convergence board are probaly what killed the origional convergence module, and likewise has killed the new board. You will need to change the convergence ICs first then replace the convergence module.
I would recommend getting the service manual . I can post a link if you would like.
Mar 17, 2008 | Televison & Video
HC-P4752W - IC Replacement vs Convergence Module.
The colors weren't lining up correctly on my HC-P4752W which is only about 30 months old. I did a little bit of research and got ahold of the people at They recommended replacing the IC's as well as the IC resistors. I purchased the replacement parts from their site and made the repairs myself. I should mention that I didn't have any previous soldering experience. The repair was easy and a complete success. You may find replacement parts elsewhere for slightly cheaper but what you won't find is the prompt and detailed customer service that they provide. They gave me there # and said to call if I had any questions before or during repair. I took advantage of their services and got answers every time I called.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
