Question about Sony PlayStation Portable (PSP) Console
No memory stick inserted
My psp says that there is no memory stick inserted, well infact there is. Tried formatting it using my psp but it says "format failed".
    Problem Solver:
  • 22 Answers
I wood say your psp is mest up in the head you need to get that fix
Posted on Jul 11, 2008
Just bought a Sony Memory Stick PRO - HG Duo 8GB for my PSP to make sure I had enough memory to do what I want. The PSP reads my old SanDisk 512 MB but says there is no memory stick inserted when I use my...
Have you tried to format in the PSP. Go to System in the main menu, then system settings, then format memory stick. I purchased a new chip for mine and it did not show as storage till i did this. Insert or remove chip only when unit is powered off. If it still does not work take it to the store and have it checked. Hope it helped.
Sep 03, 2010 | Sony PlayStation Portable (PSP) Console
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
When I attempt to delete information from my psp memory stick a message states that there is no memory stick inserted
you might need to format u your memory stick in order to use it. insert the memory stick into your psp and go system settings, scroll down under system settings to format Memory stick.
Mar 07, 2010 | Sony PSP (Piano Black)
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
Can't read the files on hte memory stick
Backup your files and format the memory stick using the PSP your having problems with.
it is possible that the memory stick being used was formatted using a diff firmware.
May 27, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick does not work
Connect the memory stick to your PC and format there. If it still fails, it's highly likely that your memory stick needs replacement
May 17, 2009 | Sony PlayStation Portable (PSP) Slim...
Formate memory stick
try formating the card using a digital device such as a camera or a playstation portable (PSP)
May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick problem
ur memory is skrew you need to get a new one i got the same problem.
May 17, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Turn the psp on go to system settings then format memory stick then insert the memory stick and format it and it should be fine.
Jan 28, 2009 | Sony PlayStation Portable (PSP) Slim...
Use a Card reader to format your Memory stick and then put it back to your PSP and again format. Some times the PSP wont recognise memory stick and contents in it.
Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
