Question about Sharp Office Equipment & Supplies
AR-M455N call for service code:L4-02 on screen day after machine was serviced. How do we clear it?
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
SOURCE: LE CODE
This problem started to occur for me about a week ago in about the same way as others have indicated, AND about 16 months beyond the expiration of the warranty. This CANNOT be a concidence. What a tick off! Also, the 800 number "help"line is a joke.At this point I am about ready to file a class action lawsuit, or at the least bad mouth this product to whomever, in or out of the media, will listen. Can I get an AMEN?
Posted on Jan 26, 2009
  • 86 Answers
SOURCE: Gestetner DSM627 Service Code Problem
These SC errors are related to the Hard disk.
Re - enter SP mode: Clear, 107 and press and hold Stop button for 3 secs.
Enter SP 5832-008 and press #,(Mail Tx data) to initialize the HDD. Then switch off and on the machine.
If still with error, replace the HDD.
Attention not to change any others SP modes - very sensitive settings!
Good luck and please rate me, thanks.
Posted on Feb 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Tray
sir my machine sharp AR-m420u take code H3-01 whats meen this code......?
Dec 03, 2013 | Sharp AR-M455N Copier
Code H5-01 on Sharp AR-M450N. Cleared jam. How do we reset? Thanks
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
Oct 14, 2010 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Sep 05, 2010 | Sharp AR-M455N Copier
I have a sharp ar-m455n and it is stuck on 59% memory on the fax. There are no faxes pending it has been like this for quite a while. Repairman says its ''normal'', but I have had 100% memory before. what...
Something the fax received into memory has corrupted its RAM or it received bad data/info. You can clear this problem by going into service mode by pressing the following keys : (PS. you must be in copy mode) P * C * then enter 66 and "start" then you can use "7" to try and print out what is stuck in memory or enter "10" to clear out the image memory then press "start".
Reset copier after that and you should be good.
Mar 22, 2009 | Sharp AR-M455N Copier
How to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Dec 20, 2008 | Sharp AR-M455N Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
549 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
