Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Posted on Jan 08, 2011
Can't get remote connection to office desktop..works in office..doesn't work at home...
Rod
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jan 08, 2011
 Rod
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
1232
Points
47
You have to configure port forwarding on the router, you must figure out what port the office computer is using for the remote connection, the configure that in the router..
2helpful
2answers
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
1helpful
2answers
Best way of total remote control of office computers, from home? Don't mention teamviewer. Looking for real solution, like windows server, can I have installed windows server on my home computer via...
As long as you aren't using linux on any of the workstations, I would whole-heartedly recommend LogMeIn (www.logmein.com).
It is free and allows you to access any computer on which it is installed through ANY web browser.
2answers
I'm trying to connect a remote desktop equipped with Linksys network adapter to internet via a home LAN. Though the network shows that it is connected to the home LAN, when i attempt to connect to...
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
2answers
I am a transcriptionist who is remotely accessing a work computer
I looked a the Infinity IN-USB-1 foot pedal, thanks. I would go out and buy a second foot pedal for home then you can remote your work pc by using the foot pedal from home. Make sure you install the drivers for the foot pedal at your home pc. If this doesnt work, you can always take the pedal back to the store. I figure that If you took away your mouse from your home pc, you could not move your mouse on the work pc. It maybe the same with the pedal. Let me know if it works.
WBTech
I want to connect at home
Around the office, your laptop is probably connected to a wireless network which you don't have at home. To connect, you would need to connect to the office network from your home through a VPN (Virtual Private Network) over the Internet or through a dial-up (ugh!) connection to the office systems. Your office IT staff should be able to help you get that set up since either way it would require some configuration on their end to allow you to connect remotely to the office systems.
3answers
No Networks Recognized when I upgraded to XP Pro
Are you using a wired or wireless connection?
Check the Device Manager to see if there are any missing drivers or yellow exclamation points.
Report back.
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
VPN connects Remote desktop will not
Make sure that the firewall doe's nt block tcp traffic on port 3389.
Hope this help.
Usually all the traffic should be allowed thru the tunnel.
3answers
Have computers in 2 locations 3/10 of a mile apart. need to network these computers. WiFi will not work because of trees. Ethernet is not feasible because we cannot string wire on posts. Internet? Need...
Directional usb antenna may be an alternative.
link
There are other usb antennas that can work for your situation, this is just a simple solution.
What is your budget?
this other product has the wireless card attached.
2answers
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Top Westell Wirespeed Computers & Internet Experts
Sean Wright
Sean Wright
deton8 von Splosion
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
