Question about SanDisk Sansa MP3 Player
REG - windows not recognised
I get the following message after connecting the SANSA EXPRESS to my PC. "USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it. For assistance in solving this problem, click this message." (But of course, clicking the message only tells you that it's an unknown device.)
I tried with two more PC’s but it showing the same error msg.
Please assist me, waiting for your sincere reply.
mail to me:chandran_a@hcl.in
  • khasimask Mar 16, 2009
For some models pressing select and the + volume button for 10 sec resets the device and it is recognized by the pc on connecting. Check ur manual to check the way to reset ur device. You can download the manual from http://www.sandisk.com in case you have misplaced it. Drop me a mail at balneet_83@yahoo.com to let me know if the solution worked for you.
Posted on Aug 09, 2008
On the SanDisk Sansa Exprss 1GB, I found the only thing tht works is when you disconect the devise from the USB, hold the volume+ and both squares by the screen aka the selecttion and the silver solid square all at the same time. so you're holding down 3 buttons at one time, volume+, thumb presses both main squares at the same time. then recharge into USB.
Posted on Sep 05, 2008
Had this problem too. If you are using one of the front mounted USB ports on your case try using one of the rear ones that are mounted direct to the motherboard. I recently built a new system with a Coolermaster case and found the case mounted USB gave this problem. No idea why as everything else I plug in there works fine. Fortunately my monitor has a couple of USB ports so I don't have to grope around behind the case.
Posted on Sep 01, 2008
My sansa clip (blue) does not charge when I connect it to the usb port on my computer. I've tried resetting it and using other cables but it still does not accept a charge. The computer does not recognize...
Why is my Sansa player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
The Sansa player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day...
Mar 02, 2011 | SanDisk Audio Players & Recorders
My sansa put with my pc for charging is not recognised by the computer today & the screen of sansa shows writing It is not getting switched off after detatching from my p.c tell me how I can bring...
Hi, sansa player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see sansa player not recognized by a MAC OS
STEP 1 - Connect the sansa player to the PC
NOTE: sansa Players can connect to your computer in MSC or MTP mode. Exceptions are sansa Connect and sansa Express which only use MTP mode. MTP mode is the recommended and default method for sansa Players when used with Windows OS.
The sansa player will show up on Device Manager's right pane as:
Have a nice day....
Feb 22, 2011 | SanDisk Audio Players & Recorders
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
4. Power issue.
- Run the hotfix.
SOLUTION 3 - Connect using MSC mode
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
I have a sansa mp3 player and i put music on it the other day but when i plugged it in yesterday it said it had software that could be installed so i clicked on it and i didnt have the cd it came with so...
4. Power issue.
- Run the hotfix.
NOTE: If you are trying to connectto a Computer at work that is part of a network, there may be userright restrictions that are set to disable access to new hardware orstop any program installations. You may need to check with your ITadministrator to see if this is causing the problem.
- If the player does not turn on try other USB ports or on anothercomputer if one is readily available. Ensure you are connectingdirectly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show upin as a storage device in an explorer window, then the screen is justnot working.
NOTE: Sansa MP3 Players canconnect to your computer in MSC or MTP mode. Exceptions are SansaConnect and Sansa Express which only use MTP mode. MTP mode is therecommended and default method for Sansa Players when used with WindowsOS.
NOTE: If a device with yellowexclamation point (!) continually appears and disappears, then theplayer is most likely failed. Additional troubleshooting is unlikely tocorrect the problem.
Connecting in MSC mode will help determine if there is a problem withMTP mode or with the Auto Detect mode feature of the player. You canuse Forced MSC mode or switch the player settings to MSC.
NOTE: Sansa Express and SansaConnect do not have MSC mode. For Sansa Connect you can tryreinstalling the firmware using the Connect Recovery Mode.
If you have replaced the Sansa Player and you still have problemsgetting it to recognize in the computer, then you may need to try someadditional troubleshooting.
If u have more questions, u can visit below sites:
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
Good luck.
Feb 25, 2010 | SanDisk Sansa e270 MP3 Player
Computer does not recagnize MP3 player when connected
4. Power issue.
- Run the hotfix.
if u want more help u can go with these site:
wish above can help u solve your problems.
Jan 06, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Usb does not recognise external hard drive
try using all available USB ports......or install chipset driver of laptop...do reply back
Oct 05, 2009 | Toshiba Tecra 8200 Notebook
Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Jul 11, 2008 | SanDisk Sansa MP3 Player
Sansa e260 mp3 player
my e260 sansa mp3 player dont recognized by computer what to do
May 06, 2008 | SanDisk Sansa e260 MP3 Player
MY Sansa Express, says USB malfunctioned, when connecting to PC
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa MP3 Player Logo
195 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
