LG LHT754 no sound from speakers
Hello I called LG they were of no help. The sound does come through the TV (I use HDMI) however no sound through Theater speakers regardless of if Im playing a DVD, Music CD. I went to the Test and the system looks as though it tests all speakers but I hear nothing. Help.
  • quichiec Sep 13, 2008
    I have the same problem but mine is more than a year. We'll wait if somebody came up with the fixer.
  • TypoPR Nov 09, 2008
    LG LHT754. Same problem. Suddenly it quit working. Plays only DVDs and CDs -- none of the other functions work. Won't play through speakers but will play through TV on HDMI cable.
    Just a week out of warranty. I'm peeved.
Hey I had to send it back, took two weeks but there was nothing else I could do. Good news is it works like its suppose to.
Posted on Sep 03, 2008
Got the same Gawdam problem. After waiting a week for this thing to show up the last thing I want to do is ship it out again to LG for repair. What a drag.
Posted on Sep 02, 2008
How do I connect ILive ITO82B Sound Bar to an LG TV?
This will depend on what inputs your sound bar has and what outputs your LG TV has, typically LG have Optical DIgital Audio (Sony TOSLINK), Headphone (Analog stereo), And HDMI reverse audio from HDMI 1 only. On some LG TV's you have to turn the external sound on, and on others it is auto detected, also make sure the TV speakers are off, or you can get weird phasing from 2 outputs (TV + Soundbar).
Jan 04, 2015 | LG Televison & Video
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Where was my problem solution posted on this site?
I only see one previous post of yours at FixYa, about a password to some unspecified website.
If you posted your question on some other website then please go to that website to find solutions.
Jan 24, 2014 | FixYa Service
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How do I get tv audio out of my surround sound HT3550U. I have HDMI cable in and function turned on TV audio. I also have LG TV. Any Ideas ???
What is the TV source?
If you have a coax (antenna or some cable systems) to the TV, then you need to connect the surround sound system to the audio out of the TV. Depending on the TV, the output could include Digital audio, RCA audio (red/white) or a headphone jack. Without knowing which LG TV model, I can't be sure which ones you have. Get the best cable for your TV/receiver system and connect that. Then set the TV to use the external speakers.
If the source is a set-top box, then the cables should run HDMI from the box HDMI out to the receiver HDMI in and then from the HDMI out of the receiver to the HDMI in on the TV. (Most TVs do not have HDMI out.) If the unit still doesn't play the audio, first try new cables and make sure the correct source is selected (some receivers have multiple HDMI in). Make sure the speaker cables are all connected (if they have separate connections) and that everything has power. (One of the usual speaker system problems in my house is loose cables from someone knocking against the back of the entertainment center and pulling.)
If you need more help, please provide more information on your equipment. I will do my best to help you diagnose the problem.
Nov 11, 2010 | Audio Players & Recorders
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
LG Model LHT754 stuck in demo mode
press power button on tv,then scroll right to take it back to tv
Jun 30, 2017 | Audio Players & Recorders
LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Jun 17, 2008 | Audio Players & Recorders
Speaker Problem
no sound out of my Lg-lht754 system, only video. Could someone help me out.
Dec 10, 2007 | LG LHT734 System
238 people viewed this question
 Grubhead
Grubhead
