Question about Epson Stylus Photo R300 InkJet Printer
Epson r300 how do I move the cartridge holder to change the ink?
Power on...press advance button....press down arrowed button until options in printer screen stops...press maintenance button....ink cart replacement appears in window ...press OK
Posted on Jul 16, 2008
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
How do I change the ink cartridge on my Epson R300 photo printer
You can find the manual here:
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
on page 90 - 91 there is a description how to replace the ink cartridges.
Mar 11, 2011 | Epson Stylus Photo R300 InkJet Printer
In the maintenance section Inkjet Cartridge Repacement does not work. The cartridge does not move into position to be replaced.
Hi!
Does it make a grinding noise when you change the button to replace the ink? As if it is trying to move the cartridge holder to a position where you can replace the ink?
If the cartridge holder has like a lock to keep the ink cartridges in place, try to use a flat object that you may insert to push it down.
One or two things- you may have not close that ink latch properly so it won't move, or the mechanism for printer is damaged.
Thanks for your time and using Fixya Online Support. Cheers!
Jan 02, 2011 | Epson Stylus Photo R300 InkJet Printer
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
Dec 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Changing a cartridge low in ink (less than 5%)
Please download the user's manual here: http://files.support.epson.com/pdf/r300__/r300__u1.pdf. The instruction is on page 90. You should be able to open the cartridge cover if you follow the instruction.
Sep 02, 2009 | Epson Stylus Photo R300 InkJet Printer
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Error with me epson r300
Hi-
when you go ro check ink levels- is it saying that there is a specific cartridge that you need to change? red light indicates no ink and all of the cartridges should have ink in it. try uninstalling cartridges and reinstall it and make sure you hear a click when you press it down. if that doesnt work,call epson 562-276-1300 for a complaint and replacement of ink. best i got!
thanks for using fixya!
Jun 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
336 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
