Question about Kenmore 22422 Top Load Washer
CE Error message on Whirlpool Washer, top load
We get this error code every now and then which leads me to believe the quick connector might be loose at the motor terminal. Where is this so I can check.
Thanks ini advance for your help!
    Genius:
  • 1,028 Answers
Must be a calypso best place to start is under console force putty knife under corners of console and push release clips lift console off two control bds underneath ..doubt you'll find bad connection but worth a shot..more likely control bd usually the one with all the relays but could be other also
Posted on Jul 22, 2008
Ce code? on calypso washer
Hello there
The CE error stands for "Communications Error" and refers to a breakdown in communications between the machine controller and the motor controller. In practical terms, this problem is usually caused by a bad wire connection. The most common trouble spot is the quick disconnect at the motor connector-I've seen this problem a lot. Usually, if you just take off the connector and re-attach it, that clears it up... IF the appliance gods are grinning down upon you. But, you may not be so lucky and you may have to make a sacrifice in the temple of Appliantology to appease the appliance gods. Y'see, lots of other things can cause the CE error, too.
00110221.jpgFor ezzample, another common problem is a blown fuse on the motor controller board. Unfortunately, this ain't a trivial repair like re-seating the quick-disconnect plug at the motor connector. Nawsir, in this case, you gotta replace the entire motor controller board.
Now, you might delude yourself into thinking you're being all slick and clever by replacing just the fuse and save a wad of moola. Oh, my, but how I giggle and nearly wet myself when disheartened grasshoppers tell me of their folly in replacing the fuse on the motor control board only to
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stops and a code of CA or CE appears. what to do?
The CE error stands for "Communications Error" and refers to a breakdown in communications between the machine controller and the motor controller. In practical terms, this problem is usually caused by a bad wire connection. The most common trouble spot is the quick disconnect at the motor connector-I've seen this problem a lot. Usually, if you just take off the connector and re-attach it, that usually clears it up.
Nov 27, 2010 | Kenmore 24032\24036 Top Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Press STOP/CANCEL to clear the display.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How can i fix the CE code on my washer? the CE code appears when i turn on the washer then it turns off.
The "ce" code indicates that a communication error occurred between the central control unit and the motor control unit. This can be caused by poor or loose electrical connections, especially at the motor connector. Unplug the machine before attempting any repair. The electrical connections can be unplugged and reseated to clean off corrosion. Also look for any damaged or burnt insulation on the wiring. If these steps fail to resolve the problem, you may want to consult an appliance repair technician for assistance. Sorry for your trouble and best wishes.
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer keeps flashing CE code and turns off.
This indicates a communication error between the central control board and the motor control board. Since you said that the fuse is good, a common trouble spot to check is the quick disconnect at the motor connector. Sometimes, unplugging and reseating this connector will clear up the problem. (If you are lucky). Hope this helped and best wishes.
Aug 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22422 Top Load Washer Logo
24 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
