Question about Cosco First Ride Deluxe
Re-thread straps on car seat
I got your email. I have dial up email service and cannot download the videos.
I have looked at the titles and don't think they are really what I am needing. I know how to install the car seat.
I need some type of diagram on how to re-thread the car seat straps.
Thanks!
kigerstamper
SOURCE: I need to put the cover back on the baby's car seat and can't remember how! Help!
You've probably already figured this one out - but for any of you having trouble getting everything back together, might i suggest www.djgusa.com
YOu can search for the manual ONLINE to YOUR particular model number (right on the side of the car seat) - I have a car seat from a friend, so i didn't have a manual to consult - until NOW!
Posted on Jan 07, 2008
quare3
  • 48 Answers
SOURCE: Converting to a Booster Seat.
Better yet, please use this manual for clear instructions and dont forget to leave a rating for me. Thanks!!!
http://www.coscojuvenile.com/instructions.asp
Posted on Jan 25, 2008
SOURCE: Need instuctions
washed the cover , now i am trying to put it back together.
Posted on Mar 09, 2008
  • 6 Answers
SOURCE: Cosco Alpha Omega Elite car seat
Manual is available at the manufacturer's website
http://www.coscojuvenile.com/instructions/
Posted on May 01, 2008
kevin000
  • 1847 Answers
SOURCE: rethread car seat straps
check this link it will help you
http://www.carseatsite.com/videos.htm
Posted on Jul 11, 2008
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
I recently removed the cover of my maxi cosi priori car seat to wash it. Now I cannot work out how to put it back on. Basically I have unhooked both shoulder straps that I think were previously threaded...
Good Afternoon
Go to www.maxi-cosi.com and select the CabrioFix carseat to download a replacement instruction manual for details of how to replace the fabric.
The harness should not have been completely removed from the carseat in order to remove the fabric. If the harness has been completely removed we cannot advise that you re-thread it due to the safety implications of it being incorrectly done. In this instance please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss the carseat being sent to our engineers for them to re-thread the harness.
Aug 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Hello, Have used Nania Newfix Solo child seat very satisfacorily for 3 years with harness. Now time to remove harness (leaving back of Childseat in place). Have removed harness as per instructions -...
Right,
After several months of struggle to find written instructions how to attach the central harness adjustment strap (The one with metal anchor at the end) to the red clip (buckle) strap as seems to be shown in instructions. budyn71.jpg
I have found number to temtex uk company that supplies nania products to argos on 01162844910, while emailing them on sales@teamtexuk.com had no result. There's no need to attach the two. Central harness adjuster strap has to be detached and pulled by it's front end as far as it goes. budyn71_0.jpg
While red clip strap threads through the gap between backrest and the base. budyn71_1.jpg
And red clip strap threads through hole (bracket) at the back of the base. budyn71_2.jpg
Sep 26, 2010 | Nania Solo Combination
I need help threading the straps correctly on our convertible car seat. We had to wash the cover and can't remember how to get the straps back. Thanks.
Welcome to FixYa
Dear User,
I think it is better to See this link to get Detailed Instruction of Installation of Car Seat.Check this link.Here is also Step by Step Video.
Hope you got it...Thanks for Connecting Fixya
Aug 30, 2010 | Century Baby Gear
How to thread the straps?
After heavy digging, I found the instruction manual for my Alpha Omega Elite 3-in-1 Car Seat #22-755-MAC and scanned it. If you are still interested, let me know your email address and I'll send the section that covers the straps. The entire document is about 8MB. I can send that if your email service can handle it. On the other hand, if you know of an ftp site I can drop it on, let me know.
Nov 13, 2009 | Eddie Bauer 3-In-1 with Latch
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Cosco First Ride Deluxe Logo
126 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
