Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper jam cannon pixma 210 bought 5/31/08 worked fine now it shows jam on rear feed, tried different weight papers, shook it, ran head cleaning etc. A permenant jam I can't free up--read 7 others having same issue. I bought at Best Buy and have receipts but no box---How can I get an exchange without them sending it out for repair and not having any printer? rbh6813
Read about the 7 other people who had issues so I emailed cannon and told them of my problem and stated I just bought it and that having the fact I am a real estate agent working from home that I needed a copier. What solutions did they offer. I was emailed they would exchange for a refurbished one asap and my new one was shipped the same afternoon. I return the defective one keeping the other stuff. Amen. Thank you for your reply. rbh6813@gmail.com
Posted on Jul 12, 2008
Lexmark 7675 paper jam
> feeds unevenly
Usually, there are two, maybe three, rollers that should _evenly_ pull the paper through the path.
Check that each roller is making good contact with the paper.
> out of paper error-message
There's a small sensor, and usually a "finger" that rises when the weight of the paper is not sufficient to hold the finger down. Check for "dust" clogging/blocking this finger.
If all else fails, it's time to take the printer to a qualified technician, for a professional cleaning & tune-up.
Apr 16, 2010 | Office Equipment & Supplies
The paper will not feed on the left side
Every time I see these I find pens, candy, clips, other objects have fallen down the back where the paper goes. One lady picked up her printer, turned it upside down and shook it and a bic pen fell out, It worked fine after that.
Nov 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Mine does the same thing--feeds sideways into the printer--pulling more to the right--then jams up. I turned it upside and shook and shook. Turned it sideways and shook and shook. I cleaned the rollers...
The guide rollers are smooth. this oftyenj occurs due to impregnated ink. I see you have cleaned it ( with alcohol?) which is a good start.
Use one of those green ploastic scourers and roughen lightly the guide wheels and the platten ( large roller) I would also suggest trying a different grade and brand of paper in the unit. Some papers just wont feed as they are designed for lasers rather than inkjets etc and vice versa.
please rate our help to keep the service online
Aug 17, 2009 | Office Equipment & Supplies
Error code 30 - printer not activated on Cannon 210
E3-3 = Paper jam
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD over current error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper feed jamming, both front and auto rear feed, I'm using plain a4 paper. Can't print out at all as the paper just won't feed in
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-25
Jul 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer not feeding paper correctly PIXMA MP510 multifunction Printer
Not sure if it will do it for you guys but after poking around, shaking, etc etc, i hadn't found a solution to the paper jam, I ended up trying to scan and print something, and, the paper aligned better at first and then i tried again after some error messages popped up, turned off the printer, rescanned and it didn't sound good at all, but dislodged a nail, that had fallen into the back cavity! now its working fine, so give it a shot, could just be that something has fallen in and is lodged. hope this helps.
Mar 10, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
89 people viewed this question
old marine
old marine
