Question about Garmin nuvi 1300 Car GPS Receiver
HOW DO I RE CALIBRATE THE SCREEN? - Garmin nuvi 1300 Car GPS Receiver
  • 321 Answers
Take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Posted on Jan 07, 2011
    New Friend:
THANK YOU MY BROTHA!!!
Posted on Jul 02, 2015
SOURCE:
How do I calibrate my windows PC monitor?
To calibrate your screen you have to open the control panel by clicking on the start button then the control panel in the right collum. Type "calibrate display" into the search bar in the top right of the control panel window. Open the calibrator by clicking on "calibrate display color" you may have to have administrator permission to calibrate the screen. Then follow the instruction on the screen.
Oct 20, 2013 | Computers & Internet
Calibrate screen
Hi Wes,
Tap "Settings" from your device's home screen. Touch "Calibrate" to calibrate your device.
Read more: http://www.ehow.com/how_12187564_improve-pandigital-novel.html#ixzz2YehEkBY6
Hope this Helps.
Please Rate if it did.
Thanks,
Gary
Jul 10, 2013 | PANDIGITAL Novel 7
My touch screen is not working frequently. Give me the solution? How to restore my phone when touch screen is not working
Hello there,
If your touch screen is not working frequently, what you have to do is to calibrate the screen or check for the touch screen sensitivity. To calibrate the screen, go to the menu of the phone and select the settings, from the settings select the screen option, then you select calibrate screen and follow the rest of the instruction there on, or you select the touch screen sensitivity and increase it from there.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 5250 Cell Phone
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
How do I calibrate my touch screen
Calibrate the g1 touch screen on the device by going to Start>Settings>System Tab>/Screen then Click Align Screen If you cannot get to the Screen Alignment utility using the menu’s, it can also be accessed by pressing the Volume Up and Center Navigation Buttons at the same time.
hope this helps, pls appreciate by rating as fixyaa
Jan 13, 2010 | HTC G1 Smartphone
Calibrate ds lite
If you would like to calibrate your screen...
Turn the DS on without a DS card inserted (or with auto mode turned off).
Then touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon, with a crosshair in it.
You will then be taken to the calibrate screen.
Touch the small red squares on the screen as they appear.
Press confirm, exit menu.
Jan 06, 2010 | Nintendo DS Lite Console
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Jul 22, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My screen wont calibrate
Do you mean you calibrate the screen and you can never accept the changes?
The lower screen in the DS Lite is actually 3 pieces. The lower screen, then the touch screen on top of it and then a clear plastic cover on top of that. If you are very rough with stylus on the clear plastic and leave dents or gouges this will damage the touchscreen.
From your basic description the touch screen needs to be replaced.
May 25, 2008 | Nintendo DS Console
Garmin nuvi 1300 Car GPS Receiver Logo
981 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
