Question about Canon PIXMA iP1500 InkJet Photo Printer
Poor print quality
No matter how many times I clean the nozzles, the print quality is awful, and I can't print in colour without it being streaky.
  • 1 more comment
  • Anonymous Aug 02, 2008
    Installed new black cartridge and print is now all blurred
  • Anonymous Nov 05, 2008
    Also had the same problem where the pictured looked all split up.
    shame about haveing to buy an new one.
  • quinnski Dec 30, 2008
    replaced blk cartridge and the canon ip1500 doesn't print properly.  It did before, so what could be the problem.  I cleaned the nozzles per the Utility info on the machine, did an alignment and now it leaves a few sentences streaky.
Your heads are defective due to a mumber of reasons. cheaper to buy new one
Posted on Jul 11, 2008
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printing quality poor
Try this one, Turn on the printer, Take out the inks, remove the
printhead, put back the printhead make sure it will snap and you hear a
click, put the inks back, wait for the printer to initialize, Press the
Menu button, look for Calibrate printer, then print calibration page,
then scan it after. Load a regular paper. Then try to print a demo page
If
same problem persist call this no for further assistance 1800 421 6699 Thanks
Aug 14, 2009 | Kodak ESP 5 Printer
Poor print quality- streaky lines across the page
The problem might be with the type of paper you are using. Some printers require different paper types. Check the manufacturers website to see what kind of paper you need.
Jul 08, 2009 | HP DeskJet 845c Printer
My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Poor print quality
First Perform deep print head cleaning if this fails and the print results are same then you may need to replace the print head on the printer .......
Good luck...
Sep 16, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Epson RX560 problems photo printing
RX 560 a printer error has occured see documentation
Sep 03, 2008 | Epson Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
182 people viewed this question
old marine
old marine
