Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search. This information is for an electric, generic model dryer only!
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site. You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information. ---------------------------------------------------------------------- Temperature Switch: Make sure a positive heat selection has been made. Then check these:
Note: A volt-ohm meter is beneficial in performing these electrical tests.
If your dryer doesn't heat, Check: Power from the house Heating element Thermal fuse Wiring Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue. Thank you, Dave E. (Illeagle) "Your satisfaction is my personal reward"
HE2 plus shuts down with F-20 error code about 9 minutes into every cycle. We have had the pressure...
(More)
HE2 plus shuts down with F-20 error code about 9 minutes into every cycle. We have had the pressure switch replaced. The problem still exists.
