Question about Symbol MC9090 Barcode Scanner
Connect MC9090-G to an Intermec 2100 Access Point
I have a client who is trying to connnect an MC9090-G handheld to an Intermec 2100 access point. He is transitioning from Intermec to Motorola/Symbol equipment. The MC9090 sees the network, but can't connect to it. Any ideas?
  • 1 more comment
  • Thebargeman Aug 07, 2008
    I am trying to connect to a wep 128 encrypted wifi and no joy
  • Anonymous Mar 28, 2014
    When a warm or cold boot won't bring back system on 740 Intermec handheld computer
  • 97 Answers
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Posted on Mar 26, 2009
    Scholar:
  • 117 Answers
There should be no issue as both are suporting the WiFi tndards. Try to deactivate the 802.11d in the software Fusion client.
Posted on Sep 21, 2010
I have installed Tenda W301A access point in my home. Only one PC can connects to the access point. If i try to connect other computer, its shows limited connectivity.
I assume you mean there is no internet connection except for one PC. You cannot connect an access point to the internet and distribute the internet access. For this you need a router.
AP does typically also not have a DHCP what would allow several clients at least to connect to each other.
Nov 03, 2014 | TENDA 300mbps Mimo Wireless N Access Point
I just got a ps3 and i cant get i on line it says wrong ssid how do i check this
Improve the Fixya.com experience for everyone by voting!
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues
Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
ssid example SSID
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jul 03, 2011 | Arris SURFboard SBG900 Wireless Router...
I'm trying to connect another computer to my home wireless network. When editing my profile it asks for the Network name (SSID). What's (SSID?
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless networkmag-glass_10x10.gif administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID Security Issues Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
All the best
Ben
Jun 06, 2011 | Computers & Internet
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
What is the intermec 2100 wireless access point used for?
Yes.
Get a spec sheet from here
http://www.barcoding.com/prodpages/Intermec/mlanap2100.pdf
Intermec's MobileLAN access 2100 offers the best in performance and range for Access Point technology. The 2100 is built to handle the demands of challenging industrial wireless networking while managing all your wireless LAN needs. Intermec's MobileLANaccess 2100 supports IEEE 802.11b High Rate WLI-F 2.4 GHz OpenAir 900 MHz Falcon and S-UHF radios. Long-range radio options and patented dual radio support help protect your investment for future migrations. Electronic software distribution simplifies system management. The 2100 offers HP OpenView WWWbrowser Telnet FTP DHCP(Client and Server) BootP and SNMP management options. Simplified software download capabilities. With the 2100 you have a wide selection of external antenna options least cost routing (maximizing bandwidth) and priority queues for superior overall performance in wireless access for your enterprise. The MobileLANaccess 2100 offers advanced network filtering and flooding features. Design the optimal network with Echo diagnostic protocol Client ARP transition for associated nodes and station parameter registration. Utilize the flexibility of broadcast-unicast flooding static and dynamic filtering and much more
Jul 15, 2010 | Intermec (2100D511704704) 802.11b Wireless...
Hello, I have symbol MC9090-K. I am trying to connect it to the WIFI. The device shows the access point but unable to get an IP address i check the status in IPv4 it shows 0.0.0.0 or it renews for few...
It appears you device can not gain access to you DHCP server to obtain an IP address.
Simple solution would be to assign a static IP and then test.
Do the intermec scanners obtain there IP address's vias DHCP?
If you need any further assistance then please contact us
www.biastechnology.com
helpdesk@biastechnology.com
Aug 15, 2009 | Symbol MC9090-K Portable Data Collector...
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Don't conect
if you hook your access point to your router the ip address is usually 192.168.0.50 Let me know how that works. It should take you to the access point page where it can be configured from there. I hope this is helpful to you
Dec 07, 2007 | D-Link AirPlus Xtreme G DWL-2000AP...
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Symbol MC9090 Barcode Scanner Logo
1,709 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
